Fan causing noise in audio circuit
Results 1 to 12 of 12
    Jun 2007
    Mansfield, UK
    Default Fan causing noise in audio circuit
    Hi, I've made an audio circuit that gets quite warm so I want to add a fan to it. I've tried a 12V DC brushless fan but it causes audiable interference. Is there a way to stop it?
    I have tried:-
    Wrapping the fan wires around a toroid with no effect.
    Placing a diode backwards accross the wires. This stops the fan from working.
    Running the fan through a separate regulator. No effect
    Adding capacitors. No effect or stops the fan depending on the configuration.
    Unfortunately I don't have the option to run the fan from a completely separate supply. Is there anything else I can try or maybe a different type of fan?
    Default Re: Fan causing noise in audio circuit
    What kind of audio circuit is that to be that sensisitve and heat at the same time? a brushless shouldn't make ANY noise.
    High likely some kind of Faraday cage 'round the high gain audio stage would help.
    Jun 2007
    Mansfield, UK
    It's a simple 14W TDA2030 setup as per the test circuit in the datasheet
    Jan 2006
    Istanbul
    Have a bobbin serially connected to GND of the circuit.
    Try different bobbins if you see no change.
    Totally agree with Steve. Brushless should make NO noise. Also TDA2030 is a little insensitive to noises since it is an automotive chip.
    But on the other hand you may have a ground loop that is causing noise. Connect all grounds to a signle point preferably at power supply 0.
    Ground routing could be a problematic, a poor layout as well. Disconnect your audio source, Short the input to ground and see if you still have noise.
    Jun 2007
    Mansfield, UK
    Sorry, I'm not sure what you mean by "bobbin" (not in an electronics sense anyway).
    All grounds are connected to the same power supply. The audio source is a SOMO-14D which is also powered from the same power source. I tried disconnecting the input and grounding it anyway but I still get the noise.
    This circuit is currently on a breadboard so the layout could be a problem but it shouldn't affect it that much.
