intervall timer siren
Results 1 to 2 of 2
    oeloeg's Avatar
    oeloeg Guest
    Default intervall timer siren
    I need intervall siren... with recordable time off and on...(at startup push button for time on, release wait and push again to record time off)
    I 've done it this way for now but I want also to change the sound
    Now I have to change the times each time...
    Is it more easy with timer? don't know how...
    program BIEP
    dim count as byte
    dim counter as byte
    dim time1 as byte
    dim time2 as byte
    main: 'start main program
    TRISD = %01100000
    Sound_Init(PORTC, 3)
    record:
    if (Button(PORTD,1,1,1)) then 'record time
    time1 = 0
    time2 = 0
    while (Button(PORTD,1,1,1)) 'record on time
    time1 = time1 + 1 'time1 + 1 (250ms)
    delay_ms(250) '+1 = 250ms
    wend 'end loop
    while (Button(PORTD,1,0,0)) 'record off time
    time2 = time2 + 1 'time2 + 1 (250ms)
    wend 'end loop
    goto loop
    end if
    loop: 'begin loop program
    if (Button(PORTD,2,0,0)) then
    for count = (time1/2) to 0 step -1
    Sound_Play(730, 250) 'siren
    Sound_Play(1152, 250)
    next count
    for count = (time1*3) to 0 step -1
    Sound_Play(730, 25) 'siren 2
    Sound_Play(935, 25)
    Sound_Play(1152, 25)
    next count
    end if 'einde knop D.2 detectie
    for counter = time2 to 1 step -1
    delay_ms(250) 'pauze = time2 * 250ms
    next counter
    goto loop
    end.
    Default Re: intervall timer siren
    The folks at this forum will be able to help you, I think.
    http://www.protonbasic.co.uk/
