Simple Photodiode On/Off circuit
Results 1 to 15 of 15
    Mar 2006
    China
    Default Re: Simple Photodiode On/Off circuit
    LM393 or similar low cost comparator would work. You can also try using a normal OP-amp as a comparator. National have tons of comparators and OPs that will do the job.
    What do you mean by "I will pulse the laser at a slightly different rate each time to stop people cheating". Will you have more than one gun fireing at the 8 targets at the same time or??
    Mar 2006
    China
    Read this: http://www.national.com/an/AN/AN-31.pdf (useful ways to connect an OP-amp)
    They have 3 suggested circuits for photodiodes and I suggest you look at them and figure out if you can use them. There is a reason why these circuits are made :-)
    Jun 2011
    If I just accepted that when the laser hits the diode that the target has been hit, there is nothing stopping people just using a standard laser pointer and triggering the targets. If they use the proper 'gun', it will pulse say 5-10 times in quick succession, or some other pattern that I can recognize, I don't think people will be able to flash their laser pointer that fast. I also will probably use a slightly different pattern each time.
    Aug 2010
    Maryland, USA
    If you use different patterns for each gun, you can easily keep score for each player
    -Bert
