Simple Photodiode On/Off circuit
Results 1 to 15 of 15
    Aug 2010
    Maryland, USA
    Default Re: Simple Photodiode On/Off circuit
    maybe set it up as a voltage divider, but use the comparater or A/D to decide if it's on or off?
    -Bert
    May 2008
    Italy
    You can use the pic comparator as an amplifier and solve the high impedence problem. See Microchips comparator tips & tricks @ page 31.
    Cheers
    Al.
    http://www.google.it/url?sa=t&source...TP7z0_z8fDfPxA
    Jun 2011
    Thanks for the suggestions guys. The problem is that I am going to have 8 targets. If these were all just LDRs, then it wouldn't be an issue and I could hook them up with 1k pull ups and it would be fine.
    Because I need so many, I can't really use the comparators, etc of the PIC. Is there a simpler way where I can use these photodiodes on the general I/O pins?
    I am also hunting around for some diodes that maybe have a narrow frequency range, so as to only respond to the laser. Then when there is no laser it would be a lot closer to 0 instead of 2 MOhms, etc.
    Jun 2011
    Maybe there is another way?
    If I measure the voltage coming through the photodiode, it is 4.6v normally, and drops to 4.4v when the laser is directly on it. How could I detect such a small voltage change?
    Mar 2006
    China
    If you have 8 A/D channels avaliable on your pic you can easily detect a 0.2V change. It should give a difference for aprox 30-40 steps in the reading if you power your pic from 5V.
    Disadvantage? YES several - slow and needs you to scan the A/D frequently to detect if the laser is on or not.
    External comparators - Cheap, easy to use and fast. Use a potentiometer to set the reference level on one input. Use the other input for the LDR (4.6 to 4.4V signal) and have one comparator for each LDR.
    Connect each comparator to a digital pin and then you can read the port to get all 8 values at the same time. You could also try to connect the 8 outputs from the comparators to pins that have interupt function and then you can wait for an interupt to fire and then you know you have a hit on a target.
    It all depends what you are trying to make, ambient light can be a problem and there could be better ways to solve your design.
    8 LDR targets ... and a laser.. my guess is Laser Tag system or maybe some kind of Laser fence
    Any one else up for some guessing?
    Jun 2011
    Thanks for the help. I will try your idea with the comparators, as it sounds like the easiest to implement. Can you recommend the best chip for this particular job?
    I am making a shooting target game, so when they pull the trigger I will turn on the laser and see if it has hit any of the targets. I will pulse the laser at a slightly different rate each time to stop people cheating.
    Mar 2006
    China
    LM393 or similar low cost comparator would work. You can also try using a normal OP-amp as a comparator. National have tons of comparators and OPs that will do the job.
    What do you mean by "I will pulse the laser at a slightly different rate each time to stop people cheating". Will you have more than one gun fireing at the 8 targets at the same time or??
