Simple Photodiode On/Off circuit
Results 1 to 15 of 15
    Jan 2006
    Istanbul
    Default Re: Simple Photodiode On/Off circuit
    Quote Originally Posted by bodgetts View Post
    I have a photodiode that I will be hitting with a laser diode, and I need to be able to determine when I have hit the 'target'.
    What is the simplest way to do this with a PIC? ie. Can I hook it up with just a pull-up resistor in a similar fashion to a simple button input? I only need to know when it is on and off.
    Yes, as you said, it would be one of the simplest ways to do it.
    Instead of a pulll up or pulll down resistor, use a trimmer pot to adjust the voltage level on the PIC pin when there is light on LDR.
    And for the code, use a delay routine to avoid false readings from ambient light(s) or sudden flashes.
    Jul 2011
    Hawaii
    Bodgetts
    There are a lot of ambient noise sources these days. TV remotes use a modulation frequency of around 53 KHz to modulate their controllers light source. An "on" signal is actually modulated light. Very long code sequences of the mfg's choosing are used for differentiating button functions. The code sequence is unnecessary for your application. You may want to modulate the laser on/off at some carrier frequency. Use some form of limiting after the detector. Feed the output of the limiter A/C coupled into one of the PIC timers to correlate correct modulation frequency. If you come up with the correct count after integrating over a period of time then you can say you have hit the target.
    - Martin
    Jun 2011
    Ok, the photodiode that I have is tuned for the wavelength of the laser (or close enough).
    When I hook the diode up to a multi-meter, the resistance is sitting about 2-2.4 M Ohms. If flash a regular light on it, it doesn't really change. As soon as I flash it with my laser, it jumps up to 4.5-5.2 M Ohms.
    Should I be able to make this trigger the PIC input if I use say a 3M Ohm resistor? I have tried this with 3 x 1 M Ohm resistors in series, and I can't seem to get the PIC to recognise the change.
    Jun 2011
    If I use a standard LDR, I can use a 1k resistor and detect the difference between light ( < 1k Ohm) and dark, which is in the 10 M Ohm range. I understand that this works because when 5v comes in through a 1k resistor, it will go to the PIC because the 10 M Ohm of the LDR is much higher.
    However, the photodiode that I am using has a range of 2 M Ohm for dark/no laser, and about 4-5 M Ohm when the laser strikes it. If I use 3 M Ohm, the voltage that does get through to the PIC is way too low to trigger an input. Any ideas here?
    Aug 2010
    Maryland, USA
    maybe set it up as a voltage divider, but use the comparater or A/D to decide if it's on or off?
    -Bert
    May 2008
    Italy
    You can use the pic comparator as an amplifier and solve the high impedence problem. See Microchips comparator tips & tricks @ page 31.
    Cheers
    Al.
    http://www.google.it/url?sa=t&source...TP7z0_z8fDfPxA
    Jun 2011
    Thanks for the suggestions guys. The problem is that I am going to have 8 targets. If these were all just LDRs, then it wouldn't be an issue and I could hook them up with 1k pull ups and it would be fine.
    Because I need so many, I can't really use the comparators, etc of the PIC. Is there a simpler way where I can use these photodiodes on the general I/O pins?
    I am also hunting around for some diodes that maybe have a narrow frequency range, so as to only respond to the laser. Then when there is no laser it would be a lot closer to 0 instead of 2 MOhms, etc.
