TMR0 Confusion
Results 1 to 16 of 16
Thread: TMR0 Confusion
    Default Re: TMR0 Confusion
    Appears not as seems to be working without it set?
    In the Interrupts section of the datasheet (under SPECIAL FEATURES OF THE CPU), there is a diagram that shows the Interrupt Logic.
    Only the peripherals in the red box are affected by PEIE.
    Thanks Darrel that's very clear, little by little i'm learning.
    How long to execute the reload?
    I'm now using the timers for a few things but how do you work out the value to add on to the reload value for the time it takes to do the reload?
     T1CON.0 = 0            'Stops Timer
     TMR1RunOn.Highbyte = TMR1H    'Load the Run-On (Over-Run) value (if any)
     TMR1RunOn.Lowbyte = TMR1L   'Load the Run-On (Over-Run) value (if any)
     TMR1RunOn = PreLoad + TMR1RunOn   'Calculate new Preload setting to include any timer overrun
     TMR1H = TMR1RunOn.HighByte   'Load the timer with new value
     TMR1L = TMR1RunOn.LowByte      'Load the timer with new value
     PIR1.0 = 0     'Clear TMR1 int flag
         T1CON.0 = 1            'Starts Timer
    The above for instance how much to add to keep the accuracy? How long does that all take? Any rough estimates? It's a pretty standard reload code but I could not find any examples. I'm running at 8mhz with 1/8 prescaler.
