PortC.7 general I/O output problem
Results 1 to 13 of 13
    Default Re: PortC.7 general I/O output problem
    Note 1: When the SPEN bit is set the RX/DT I/O pin
    is automatically configured as an input,
    regardless of the state of the corresponding
    TRIS bit and whether or not the EUSART
    receiver is enabled.
    The RX/DT pin data
    can be read via a normal PORT read but
    PORT latch data output is precluded.
    You can't if you're using HSEROUT
    Aug 2010
    Maryland, USA
    Are you using hserout or hserin?
    -Bert
    Jun 2011
    I am using neither hserout or hserin. I just want to use ports c.0 - c.7 for general output.
    Have I configured my pic incorrectly?
    Aug 2010
    Maryland, USA
    I think NO! ADCON = 7 is the same as ADCON = %00000111. so you have enabled the a/d and turned it on. Please correct this and see if it helps. It looks like you DO have the serial disabled as you wanted to.
    -Bert
    Jun 2011
    Ok, I changed the ADCON0 and ADCON1 to 0, still have the same problem. Portc.0-portc.6 work fine, it is just the last pin portc.7 that doesn't seem to change no matter what I send to it.
    Aug 2010
    Maryland, USA
    I don't see any reason for it not to work. Maybe the circuit is bad? Breadboard or SIM? How do you know it is not working?
    -Bert
    [mondayRant]
    Please say SIM
    [/mondayRant]
