PIC hanging on Serin
Results 1 to 5 of 5
    Default Re: PIC hanging on Serin
    onioni, using your scope, what is the level at the PIC rx pin when the system is in an idle mode (no data being sent)
    EN82fn
    Jul 2011
    Hi Dave,
    I am running the 3.3V TX output through 2 inverters then to the RX pin of the PIC, so the PIC RX pin is seeing +5V when nothing is being sent.
    onioni
    onioni, That sounds good to me. Looking at the scope, is the timing correct for the baudrate? Try sending repeatedly the character "w" I beleive which should what looks a square wave. See if the time interval for the HIGH and the LOW are the same. If there is a difference this may be due to a slewrate problem with the inverters.
    EN82fn
    Jul 2011
    I checked the waveforms on the scope and the are identical except the one from the inverter is 5V instead of 3.3V. No differences due to slew rate to speak of. I have read on this forum that it is important to read the PIC datasheet, well I just learned a hard lesson. By properly setting the CMCON0 register to allow digital I/O, the program worked like a charm. I found this out after switching the 3.3V input-output with those of the hyperterminal. The HT was then hanging instead of the 3.3V chip. I will read the datasheet more closely next time. I appreciate you taking the time to troubleshoot with me.
    onioni
