Not getting this timer thing.
Results 1 to 10 of 10
    Aug 2010
    Maryland, USA
    Default Re: Not getting this timer thing.
    YES!!!
    The test loop adds execution time, which causes your time before check to be longer.
    There are prolly some differences in how you can use timer 1 and timer 2, but if they are set up as counters triggered by fosc/4, they will count the same.
    You have a few choices in how to deal with getting accurate times. the first and always pointed at is to use interrupts. The second is to auto adjust the count while the program is running. to do this, once the timer is greater then target number, subtract target number from the CURRENT timer value. when you reload the timer, reload it with your reload value + the difference just calculated. Mind you, that is for a counter counting up. If using PR (as with timer 2) you can just load timer 2 with the difference. then it will count from adjusted number to PR value, instead of from zero to PR.
    Did any of that make sense? Both methods are valid and useful depending on application. (Thanks PBP members for the auto correct idea)
    -Bert
    Consider dt-ints and this structure.Name:  INTERRUPT.JPG
    don
    amgen
    May 2011
    I can attain the results I need through the Timer2 and with the serial comms I need to mix in, timer2 is probably the best way. Thanks to all who set me straight on this. I think I understand enough now to get me to the next item I don't understand.
