Re: Wired remote for Pioneer HU
Originally Posted by
fratello
Thanks for reply !
I do not think I understood very well ...What that means "MUST USE MPASM" ?!
Trisx.y in PBP it's not like trisx.y in assembler ?
Must use the MPASM assembler from Microchip, and not the PB assembler supplied with PBP. I am betting the simulator defaults to using MPASM and simply ignores the PB configs altogether. So when you run it, it knows what to do with Steve's keypad code whereas PB does not.Most of Steve and Darrel's code samples require MPASM, and when you upgrade to PBP3 it ONLY uses MPASM, so it is a worthwhile change.
