Wired remote for Pioneer HU
Results 1 to 23 of 23
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Wired remote for Pioneer HU
    Thanks You so much for support ! Are some thinks I dont understand (too ...) ...
    1. I dont use MPASM in code.
    2. My astonishment it's about non-function of this hardware ! If I connect JUST the resistor on jack, the HU react ! If I use same resistor -via optocoupler - the HU react ! But with PIC, dont !
    I increased the time for each tris command, but without results !
    case 1     ; volume down
     trisb.2=0
    Pause 5000 ; I try even with this huge pause !
    trisb.2=1
    endcase
    I am not familiar with the HU, but if you post the current hardware schematic (PIC, opto, HU) someone may be able to spot the problem.
    Dec 2008
    Ploiesti, ROMANIA
    So...with schematic from post #1 - no results !
    With a simple resistor - good results ; with optocouplers - good results too.
    Dec 2008
    Ploiesti, ROMANIA
    ...and how an "original" remote work :
    I haven't studied this thread in detail but if the idea is to "place a resistance" across the plug then I don't think you can run the same code (if that's what you're doing) with the two different hardware designs. When using the circuit with the opto-isolators you drive the PIC-pin high in order to turn on the opto-isolator and connect the associated resistor across the plug - and if I read your posts correct this works fine.
    It's not exactly clear to me how the plug is connected to the circuit in post#1 but it looks to me as if this circuit doesn't work the same way as the one with the opto-isolators. So, if you're trying to run the same code with the two circuits my guess is that's where your problem is.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for support, Mr.Henrik !
    When I switch to optocouplers, I changed code :
    Portb.2=1
    Pause 100
    Portb.2=0
    My "sources of inspiration" was here : http://www.panuworld.net/minidisc/fordsony/index.htm & http://www.fiatforum.com/marea/29682...-finished.html
