Wired remote for Pioneer HU
Results 1 to 23 of 23
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Wired remote for Pioneer HU
    Yes, I have not tested this scheme until yesterday ... and how I say, I found that does not work ! Even if my ohm-meter show "right" value of resistances ( at every press of buttons) the HU not react ; with optocouplers all are ok. Strange for me...The hardware it's finished, but remains my astonishment about this. Thanks for reply !
    Welllll Fratello, it seems you've been bitten by a simulator ?
    One hint from Steve's code's comments . . . " MUST USE MPASM " . . . Your configs indicate PB assembler.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply !
    I do not think I understood very well ...What that means "MUST USE MPASM" ?!
    Trisx.y in PBP it's not like trisx.y in assembler ?
    Read
    And stop using the simulator, or at least let everyone kow that you are when you post a problem.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks You so much for support ! Are some thinks I dont understand (too ...) ...
    1. I dont use MPASM in code.
    2. My astonishment it's about non-function of this hardware ! If I connect JUST the resistor on jack, the HU react ! If I use same resistor -via optocoupler - the HU react ! But with PIC, dont !
    I increased the time for each tris command, but without results !
    case 1     ; volume down
     trisb.2=0
    Pause 5000 ; I try even with this huge pause !
    trisb.2=1
    endcase
    I am not familiar with the HU, but if you post the current hardware schematic (PIC, opto, HU) someone may be able to spot the problem.
    Dec 2008
    Ploiesti, ROMANIA
    So...with schematic from post #1 - no results !
    With a simple resistor - good results ; with optocouplers - good results too.
    Quote Originally Posted by fratello View Post
    Thanks for reply !
    Must use the MPASM assembler from Microchip, and not the PB assembler supplied with PBP. I am betting the simulator defaults to using MPASM and simply ignores the PB configs altogether. So when you run it, it knows what to do with Steve's keypad code whereas PB does not.Most of Steve and Darrel's code samples require MPASM, and when you upgrade to PBP3 it ONLY uses MPASM, so it is a worthwhile change.
