Wired remote for Pioneer HU
Results 1 to 23 of 23
    Dec 2008
    Ploiesti, ROMANIA
    Default Wired remote for Pioneer HU
    Hi ! I try to build one wired remote for HU Pioneer , using remote control stalk near the steering wheel, from Renault. I wrote the code ; in simulation work fine. But...I don't know how setting ports "b" and what to do when push_button it's press.
    In "original" remote, the command are given by putting resistors "to ground". How can I do this with my PIC ? Thanks in advance !
    @ DEVICE pic16F628A, INTRC_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF, CPD_OFF, PROTECT_OFF
       Include "modedefs.bas"   ' Serial Protocol
       Define   OSC 4           ' 4MHz
       CMCON = 7                ' Disable on-chip comparator, PORTA in digital mode
       '// Define port pins as inputs and outputs ...
       TRISA  = %00000111
       TRISB  = %11111100
    portb = 1
    include "c:\pbp\keypad2.pbp" ' see http://www.picbasic.co.uk/forum/showthread.php?t=3250
    gosub keypadscan
    gosub check
    check:
    select case key
    case 1     ; volume down
       trisb.2=0    ; ?????
       pause 200    ;
       trisb.2=1    ' ?????
    Default Re: Wired remote for Pioneer HU
    one thing I would make sure before connecting this to the car... measure the .spurious/floating) voltage on the tip pin when nothing it pluged.. if it's 12 volt you want to change some part of your hardware. Case it's 5 volts (or so), well there's no problem with your current solution
    What you need to do is to clear the PORTB bits (to 0) and set your TRISB bits to 0 when you want to set a resistor to ground, and to 1 when you want to disconnect the resistor from the circuit. The more you clear TRSIB bits, the more resistor you add in parrallel. You should know how to calculate/evaluate resistors in parrallel, so, just etablish some value and work around this. Maybe you don't need more than 3-4 resistor to reproduce the whole value in the table above. If you feel lazy, then use 8 resistor and assign them to a whole 8 bits port. easier, need a bit more I/O... but easier. BTW you already get the idea as per your code.
    8 resistors, 6 button = 14 I/O, a PIC 16F628 will do the trick without any need for a matrix keypad.
    Button1 VAR PORTA.0
    Button2 VAR PORTA.1
    IF Button1=0 then set your resistor on portb
    If Button2=0 then set your resistor on portb
    or
    Button var PORTA
    Select Case Button
         Case xyz
              Set yourresistor
         Case abc
               Set another resistor
    How about that?
    Dec 2008
    Ploiesti, ROMANIA
    Thank You verry much for support !
    I use matrix keypad because the Renault remote act like one (see picture) !
    So, it's enough (?) something like this :
    case 1
    portb.2=0
    trisb.2=0
    pause 500 ; i put the resistor on portb.2 to ground for 0.5 sec
    portb.2=1
    trisb.2=1
    The "portb" it's OK to set in header "PORTB=%11111100" ?
    Sep 2009
    Set all pin to low, and then just change tris registers, instead of changing port and tris.
    Also add 5.1V zener between resistor common wire and ground.
    Dec 2008
    Ploiesti, ROMANIA
    Now it's ok ?
       TRISA  = %00000111
       TRISB  = %00000000
    gosub keypadscan
    gosub check
    check:
    select case key
    portb.2=0
    portb.2=1
    PORTB=0
    TRISB = 255 ' Disconnect all resistors from the circuit
    ' Some code here
    DoItAgain: SELECT CASE XYZ CASE ABC TRISB.0 = 0 ' Connect PORTB.0 resistor to the circuit CASE DEF TRISB.0 = 0 ' Connect PORTB.0 resistor to the circuit TRISB.1 = 0 ' Connect PORTB.1 resistor to the circuit CASE GHI TRISB.0 = 0 ' Connect PORTB.0 resistor to the circuit TRISB.2 = 0 ' Connect PORTB.2 resistor to the circuit TRISB.3 = 0 ' Connect PORTB.3 resistor to the circuit END SELECT PAUSE 500 TRISB = 255 ' Disconnect all resistors GOTO DoItAgain
    I'm confused. So, your big thank you a year ago, (and the happy dance by Steve) was for code you couldn't get working? Or you didn't try the code until now? Perhaps more explanation is required, at least for me.
    http://www.scalerobotics.com
    Dec 2008
    Ploiesti, ROMANIA
    Yes, I have not tested this scheme until yesterday ... and how I say, I found that does not work ! Even if my ohm-meter show "right" value of resistances ( at every press of buttons) the HU not react ; with optocouplers all are ok. Strange for me...The hardware it's finished, but remains my astonishment about this. Thanks for reply !
    Welllll Fratello, it seems you've been bitten by a simulator ?
    One hint from Steve's code's comments . . . " MUST USE MPASM " . . . Your configs indicate PB assembler.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply !
    I do not think I understood very well ...What that means "MUST USE MPASM" ?!
    Trisx.y in PBP it's not like trisx.y in assembler ?
    Read
    And stop using the simulator, or at least let everyone kow that you are when you post a problem.
    Quote Originally Posted by fratello View Post
    Thanks for reply !
    Must use the MPASM assembler from Microchip, and not the PB assembler supplied with PBP. I am betting the simulator defaults to using MPASM and simply ignores the PB configs altogether. So when you run it, it knows what to do with Steve's keypad code whereas PB does not.Most of Steve and Darrel's code samples require MPASM, and when you upgrade to PBP3 it ONLY uses MPASM, so it is a worthwhile change.
    Apr 2013
    did any of you build adapter for stalk steering wheel controls on renault (tuner list stereo instalation, mine laguna year 2002) for pioneer? I saw scheme above but i dont know how to wire it in little yellow miniISO 6-pin jack that is connected on steering wheel controls? Any help?
    Thank You in advance.
    Aug 2005
    the reason the original design doesnt work is due to parallel resistors not giving the required voltage at the stereo plug (due to voltage divider effects), by using opto's you are supplying discreet resistances which results in the correct voltages
