how to generate two signals from two ports at the same time by using p16f84
Results 1 to 27 of 27
    Jul 2011
    Default Re: how to generate two signals from two ports at the same time by using p16f84
    let me look at
    Jul 2011
    i guess if pic16f84 have had 2 timers , it would be easy but it has not and how do we generate two different signals by using one timer at the same time?
    so diffucult
    Aug 2010
    Maryland, USA
    the program i posted in that thread uses 1 timer. That timer is used to generate a time base to drive 4 software counters. these counters become my timers.
    -Bert
    Jul 2011
    hi cncmachineguy
    yes i recognized it but pic16f84 drived by max 10 mhz and we need so precision time period , max +-2 micro second precision, when we use instructions like if ,else we have problem.
    when we are asked to generate two signals 630 micro seconds and 453 micro second by porta.0 and porta.1, for example, 633 micro seconds is not acceptable.
    Aug 2010
    Maryland, USA
    well how about you post what you have so far, and maybe we can help you to get it done. Did you teacher have any suggestions how he thinks you will do it? I am sure there are several ways to get it done, but you must understand how and why it works. We will help you, but we won't do it for you (not saying you asked us to). So show us what you have and we can go from there.
    -Bert
    Jul 2011
    yes i have an advisor teacher but he does not say anything about how i can do it. i guess he just wonder how i find a solution for this project.
    i have started usual basic loop without using tmr0, and for a signal it works well but generating second one with different frequencies causes timing problem. i also tried to implement assembler codes in order to have more time space however it did not help me.
    at least i want to find a method so as to generate these signals having pulse witdh x8 ( 8,16,..320 mic. sec ). in this program i am trying to use basic timing by using tmr0 and interrupt. i guess i need a 8 micro seconds time period which constant?
    thanks a lot
    define OSC 10
    timer0 var word
    timer1 var word
    A0 VAR PORTA.0
    A1 VAR PORTA.1
    on interrupt goto int_timer
    OPTION_REG=%00000000
    TMR0=255
    INTCON=%10100000
    TRISA=0
    LOW PORTA
    timer1=0
    timer0=0
    enable
    disable
    int_timer:
    timer0=timer0+1
    if timer0=>3 then ' 3 is a random number
    timer0=0
    toggle a0
    timer1=timer1+1
    if timer1=>10 then ' 10 is a random number
    timer1=0
    toggle a1
    INTCON.2=0
    TMR0 = 255
    resume
    Jul 2011
    i have tried to obtain accurate time by changing tmr0 and prescaler, but still no answer
