Another 2.60 worry
Results 1 to 19 of 19
    Default Re: Another 2.60 worry
    There IS a standard, basic, working most of the time configuration fuse setting already setup for each and every chip that the compiler supports. You don't have to set them in your code if the default is OK.
    If you wan't to see how they "work" and what they are simply open the .inc file for the specific target you're compiling for, it's located in the root of the PBP folder. For the 16F886 the fileneme is 16F866.INC and looks like this:
            NOLIST
        ifdef PM_USED
            LIST
            include 'M16F88x.INC' ; PM header
            device  pic16F886, intrc_osc_noclkout, wdt_on, mclr_on, lvp_off, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 16F886, r = dec, w = -302
            INCLUDE "P16F886.INC" ; MPASM  Header
            __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
            NOLIST
            LIST
    Now, the @ DEVICE statement is used when you're using PM as the assembler and the __CONFIG (note two underscores) is used when you're using MPASM as the assembler. If you're Win7 you can't use PM which means you're using MPASM which means @ DEVICE is the wrong "command".
    In order to find out the "names" of the various fuses go to your MPASM folder and open the P16F886.INC file, at the end of that file you'll find this:
    ;       Configuration Bits
    _CONFIG1                     EQU     H'2007'
    _CONFIG2                     EQU     H'2008'
    ;----- Configuration Word1 ------------------------------------------------
    _DEBUG_ON                    EQU     H'1FFF'
    _DEBUG_OFF                   EQU     H'3FFF'
    _LVP_ON        EQU     H'3FFF'
    _LVP_OFF       EQU     H'2FFF'
    _FCMEN_ON                    EQU     H'3FFF'
    _FCMEN_OFF                   EQU     H'37FF'
    _IESO_ON                     EQU     H'3FFF'
    _IESO_OFF                    EQU     H'3BFF'
    _BOR_ON                      EQU     H'3FFF'
    _BOR_NSLEEP                  EQU     H'3EFF'
    _BOR_SBODEN                  EQU     H'3DFF'
    _BOR_OFF                     EQU     H'3CFF'
    _CPD_ON                      EQU     H'3F7F'
    _CPD_OFF                     EQU     H'3FFF'
    _CP_ON                       EQU     H'3FBF'
    _CP_OFF                      EQU     H'3FFF'
    _MCLRE_ON                    EQU     H'3FFF'
    _MCLRE_OFF                   EQU     H'3FDF'
    _PWRTE_ON                    EQU     H'3FEF'
    _PWRTE_OFF                   EQU     H'3FFF'
    _WDT_ON                      EQU     H'3FFF'
    _WDT_OFF                     EQU     H'3FF7'
    _LP_OSC                      EQU     H'3FF8'
    _XT_OSC                      EQU     H'3FF9'
    _HS_OSC                      EQU     H'3FFA'
    _EC_OSC                      EQU     H'3FFB'
    _INTRC_OSC_NOCLKOUT          EQU     H'3FFC'
    _INTRC_OSC_CLKOUT            EQU     H'3FFD'
    _EXTRC_OSC_NOCLKOUT          EQU     H'3FFE'
    _EXTRC_OSC_CLKOUT            EQU     H'3FFF'
    _INTOSCIO                    EQU     H'3FFC'
    _INTOSC                      EQU     H'3FFD'
    _EXTRCIO                     EQU     H'3FFE'
    _EXTRC                       EQU     H'3FFF'
    ;----- Configuration Word2 ------------------------------------------------
    _WRT_OFF                     EQU     H'3FFF'    ; No prog memmory write protection
    _WRT_256                     EQU     H'3DFF'    ; First 256 prog memmory write protected
    _WRT_1FOURTH                 EQU     H'3BFF'    ; First quarter prog memmory write protected
    _WRT_HALF                    EQU     H'39FF'    ; First half memmory write protected
    _BOR21V             EQU     H'3EFF'
    _BOR40V             EQU     H'3FFF'
    So, to change the CONFIG fuses you have two options:
    1) Edit the 16F866.INC file in the PBP folder to have the CONFIG you want/need. Do make a backup of the original file first.
    2) Comment out the CONFIG from the 16F866.INC file and instead put them in your code.
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Rightio, I opened the M16f88x.inc file in the PBP directory.
    That first example you gave does not exist anywhere in the file??
    This is getting all too hard..I'm gunno go play soliraire.
    I do understand that I can edit the first example you gave and make it into a new default that suits me.
    But, as I said, it ain't in there.
    Peter Moritz.
    New South Wales,
    Australia.
