PicBasic Lookup command
Results 1 to 16 of 16
    Jan 2014
    Default Re: PicBasic Lookup command
    I have something strange with loockup command. I play with a RC transmitter...
    If I turn on the pic with signal>185 then duty = 0 ; then I reduce the signal value under 185 , then duty=divf
    If I move quickly the transmitter-stick (signal from 150 ) to maximum (200) I obtain random different values for duty, like 250 ,191, 90, 223 and sometime 255.
    If I move slow the transmitter-stick , then duty = divf all time, so work perfectly.
    Can somebody explain me whats happen here , please ? I'm very confused..!!
        __config _CONFIG1, _FOSC_INTOSC & _MCLRE_OFF & _CP_ON & _CLKOUTEN_OFF
        __config _CONFIG2, _PLLEN_OFF & _LVP_OFF
    OSCCON = %01101000
    @ ERRORLEVEL -306   ; turn off crossing page boundary message
    include "lcd.bas"
    ADCON0 = %00000000
    ADCON1 = %00000000
    CM1CON0 = 0   ' COMPARATORS OFF
    CM1CON1 = 0
    CM2CON0 = 0   ' COMPARATORS OFF
    CM2CON1 = 0
    CPSCON0 = 0   'CAPACTIVE SENSE MODULE OFF
    RCSTA.7 = 0   'SERIAL PORT OFF
    OPTION_REG.7 = 1 'DISABLE PULL UP
    TRISA  = %00000000
    TRISB  = %00000000
    TRISC  = %00000000
    ANSELA = %00000000
    ANSELB = %00000000
    PORTA  = %00000000
    PORTB  = %00000000
    PORTC  = %00000000
    WPUB   = %00000000
    LATC   = 0
    divf   var byte : divf = 0
    signal var byte
    value  var byte : value =0
    duty   var byte : duty = 0
    gosub lcdrst:pause 300
    pulsin portb.0 , 1 , signal
    if signal > 185 then signal = 185
    if signal > 160 then
        value = (signal - 160) ' value max 25
        lookup value ,[0,30,40,50,65,80,90,100,117,136,153,168,180_
                     ,191,201,209,217,223,233,237,241,244,247,250,255],divf
        divf  = 0
        value = 00
    if duty <> divf then duty = divf
    lcdout $fe, $80 , "Value = " , dec3 value
    lcdout $fe, $C0 , "DUTY =  " , dec3 DUTY
    '-------------------------- LCD -----------------------------
    lcdrst:
    lcdout, $fe, 1
    pause 10
    The first value in the LOOKUP table is returned when value is 0. You have 25 entries in the table so value should range from 0 to 24. When signal is >185 value is 25 which points outside of the table in which case divf remains unchanged - so if this is at startup it remains at 0.
    This I don't think has anything to do with the LOOKUP command. Have you looked at the actual pulses being measured by the PIC, is it possible that they actually ARE varying in widht (due to noise in the stick or whatever) and that the PIC is doing exactly as it should?
