PicBasic Lookup command
Results 1 to 16 of 16
    Default Re: PicBasic Lookup command
    Weird, have you tried on a stripped version of your codeÉ
    Could you post the whole thing here?
    Assuming Lolite is an alias to PORTA, have you disable the analog and/comparator on PORTA ?
    Jun 2011
    Indian Harbour Nova Scotia
    Here is the "complete" code. This is a test area where I have all my equates and variable declarations for a bigger code, but I check little pieces at a time. The piece I'm checking now is the "snippet" I showed in previous post.
    ; Define LOADER_USED to allow use of the boot loader.
    Define LOADER_USED 1
    ;Aliases use Var, symbols use = sign
    ;Code D,C,B, A in that order, from Snowflake to Arm to Light
    ;SNOWFLAKES
    East Var PortD.0 ;Use Port D for Snowflakes and background
    Cent var PortD.1 ;connect to enable line of 74373 latches
    West var PortD.2
    Back Var PortD.3 ;likely always set to "on" to keep background lit
    ;ARMS
    Blu var PortC.0 ;Use Port C bottom nibble for arms
    Org var PortC.1
    Red var PortC.2
    Grn Var PortC.3
    Armson var PortC
    Armsoff var PortC
    ;LIGHTS
    LoLite var PortA
    HiLite var PortB
    L0 Var PortA.0
    L1 var PortA.1 ;Low Lamps 0-7 Lo.0=first inside, using port A
    L2 var PortA.2
    L3 var PortA.3
    L4 var PortA.4
    L5 var PortA.5
    L6 var PortA.6
    L7 var PortA.7
    H0 VAR PortB.0
    H1 VAR PortB.1
    H2 VAR PortB.2
    H3 VAR PortB.3 ;High lamps 8-11 Hi.11=last outside, using port B
    x var byte ;index variable for low lamps 0-7
    y var byte ;index variable for high lamps 8-11
    del var byte ;use var Word if value>255
    d var byte
    out var byte
    ;****************Program Start******************
    Initialize:
    TRISA= %00000000 ;set portA to all output
    TRISB= %00000000 ;set PortB to all output
    TRISC = %00000000 ;Set PORTC to all output
    TRISD= %00000000 ;Set PortD to all output
    Low Blu
    Low Org
    Low Red
    Low Grn
    LoLite=0
    HiLite=0
    low east ;initialize
    low cent
    low west
    ;high east
    High Cent
    ;High West
    ;Armson=$0F ; all arms on, same as High Blu, High Red, etc
    ArmsOff=$00; all arms off
    d=0
    Main: Gosub growspin
    ;*********************Subroutines***************** **********
    growspin:For d = 0 To 7
    Lookup d,[$1,$3,$7,$f,$1f,$3f,$7f,$ff],out
    Lolite=out
    pause 100 ;first 8 in about 2/sec for pause=100
    Next d ;entire snowflake in about 1 sec
    ;For d = 0 To 3
    ;Lookup d,[$1,$3,$7,$f],out
    ;Hilite=out ;
    ;pause 100 ;
    ;Next d
    ;pause 500 ;hold all at end for 1/2 second
    LoLite=0
    Jun 2011
    I figured it out. Not having played with too many CPU/MPU/MCU that are multi purpose I was not aware that the port could be analog or digital
    Initializing Ansel to 0 fixed the problem. The code works now.
    Thanks for reading this and attempting to help me.
    Reading the spec sheet (all of it), triumphs again!!
    Jun 2011
    Okay, one problem solved...now another. I'm using RA6 and RA7 and want to use the internal oscillator. I think I have to set bit 2 of CONFIG1 to 1 in order to select INTOSCIO.
    I tried config1= config1|%00000100 (|= OR) but I get a compile error. I can't find anything via Google, via other programs on how to do this.
    I'm using PIC Basic Pro. I don't want to disturbe the other bits, which is why I'm using OR.
    anyone?
    Jun 2011
    Default Re: PicBasic Lookup command update: hardware problem
    I had tried everything to get RA6 and RA7 working and when they were not (by noting the lights connected to these pins were not lighting up) I started poking around first with my logic probe, and then my oscilloscope. Would you believe it? The two signals WERE coming out of the MCU to my breadboard, and through the interface chips, but not at the end of my 4 foot ribbon cable. That's right, the signals I was looking for were there, but I had a HARDWARE problem! I had tested the cable out previously, ringing it out with an ohmmeter, but by scoping it I could see the signal wasn't getting through the 16 pin ribbon connector cable. A couple quick squeezes with pliers fixed the problem.
    Long time ago a colleague would use the term "check the wiring" for every little problem that came up. I laughed at him...
    Thanks to those who responded. Oh, btw, I didn't need to change the config bits.
