PicBasic Lookup command
Results 1 to 16 of 16
    Jun 2011
    Indian Harbour Nova Scotia
    Default PicBasic Lookup command
    I have a little snippet of code where I lookup a value and send it to PortA (Lolite=PortA) of my PIC16F887. Here is the code:
    For d = 0 To 7
    Lookup d,[$1,$3,$7,$f,$1f,$3f,$7f,$ff],out
    Lolite=out
    Next d
    -My variables are declared
    Using the debugger in MicroCode Studio:
    -Var "out" has proper value inserted for each value of "d"
    -Lolite DOES NOT equal out.
    For the first 4 or 5 values of d, Lolite =0, then for the next value of d, it jumps to $10.
    Why, oh why, oh why?
    Default Re: PicBasic Lookup command
    Is Lolite a Byte or Word?
    Jun 2011
    Lolite is a byte.
    I looked at that...but I don't see anything wrong. Lolite is a byte, out is a byte and all the values are bytes.
    What am I missing?
    Weird, have you tried on a stripped version of your codeÉ
    Could you post the whole thing here?
    Assuming Lolite is an alias to PORTA, have you disable the analog and/comparator on PORTA ?
    Jun 2011
    Here is the "complete" code. This is a test area where I have all my equates and variable declarations for a bigger code, but I check little pieces at a time. The piece I'm checking now is the "snippet" I showed in previous post.
    ; Define LOADER_USED to allow use of the boot loader.
    Define LOADER_USED 1
    ;Aliases use Var, symbols use = sign
    ;Code D,C,B, A in that order, from Snowflake to Arm to Light
    ;SNOWFLAKES
    East Var PortD.0 ;Use Port D for Snowflakes and background
    Cent var PortD.1 ;connect to enable line of 74373 latches
    West var PortD.2
    Back Var PortD.3 ;likely always set to "on" to keep background lit
    ;ARMS
    Blu var PortC.0 ;Use Port C bottom nibble for arms
    Org var PortC.1
    Red var PortC.2
    Grn Var PortC.3
    Armson var PortC
    Armsoff var PortC
    ;LIGHTS
    LoLite var PortA
    HiLite var PortB
    L0 Var PortA.0
    L1 var PortA.1 ;Low Lamps 0-7 Lo.0=first inside, using port A
    L2 var PortA.2
    L3 var PortA.3
    L4 var PortA.4
    L5 var PortA.5
    L6 var PortA.6
    L7 var PortA.7
    H0 VAR PortB.0
    H1 VAR PortB.1
    H2 VAR PortB.2
    H3 VAR PortB.3 ;High lamps 8-11 Hi.11=last outside, using port B
    x var byte ;index variable for low lamps 0-7
    y var byte ;index variable for high lamps 8-11
    del var byte ;use var Word if value>255
    d var byte
    out var byte
    ;****************Program Start******************
    Initialize:
    TRISA= %00000000 ;set portA to all output
    TRISB= %00000000 ;set PortB to all output
    TRISC = %00000000 ;Set PORTC to all output
    TRISD= %00000000 ;Set PortD to all output
    Low Blu
    Low Org
    Low Red
    Low Grn
    LoLite=0
    HiLite=0
    low east ;initialize
    low cent
    low west
    ;high east
    High Cent
    ;High West
    ;Armson=$0F ; all arms on, same as High Blu, High Red, etc
    ArmsOff=$00; all arms off
    d=0
    Main: Gosub growspin
    ;*********************Subroutines***************** **********
    growspin:For d = 0 To 7
    Lolite=out
    pause 100 ;first 8 in about 2/sec for pause=100
    Next d ;entire snowflake in about 1 sec
    ;For d = 0 To 3
    ;Lookup d,[$1,$3,$7,$f],out
    ;Hilite=out ;
    ;pause 100 ;
    ;Next d
    ;pause 500 ;hold all at end for 1/2 second
    LoLite=0
    Jun 2011
    I figured it out. Not having played with too many CPU/MPU/MCU that are multi purpose I was not aware that the port could be analog or digital
    Initializing Ansel to 0 fixed the problem. The code works now.
    Thanks for reading this and attempting to help me.
    Reading the spec sheet (all of it), triumphs again!!
    Jun 2011
    Okay, one problem solved...now another. I'm using RA6 and RA7 and want to use the internal oscillator. I think I have to set bit 2 of CONFIG1 to 1 in order to select INTOSCIO.
    I tried config1= config1|%00000100 (|= OR) but I get a compile error. I can't find anything via Google, via other programs on how to do this.
    I'm using PIC Basic Pro. I don't want to disturbe the other bits, which is why I'm using OR.
    anyone?
    Jun 2011
    Default Re: PicBasic Lookup command update: hardware problem
    I had tried everything to get RA6 and RA7 working and when they were not (by noting the lights connected to these pins were not lighting up) I started poking around first with my logic probe, and then my oscilloscope. Would you believe it? The two signals WERE coming out of the MCU to my breadboard, and through the interface chips, but not at the end of my 4 foot ribbon cable. That's right, the signals I was looking for were there, but I had a HARDWARE problem! I had tested the cable out previously, ringing it out with an ohmmeter, but by scoping it I could see the signal wasn't getting through the 16 pin ribbon connector cable. A couple quick squeezes with pliers fixed the problem.
    Long time ago a colleague would use the term "check the wiring" for every little problem that came up. I laughed at him...
    Thanks to those who responded. Oh, btw, I didn't need to change the config bits.
    Jan 2014
    I have something strange with loockup command. I play with a RC transmitter...
    If I turn on the pic with signal>185 then duty = 0 ; then I reduce the signal value under 185 , then duty=divf
    If I move quickly the transmitter-stick (signal from 150 ) to maximum (200) I obtain random different values for duty, like 250 ,191, 90, 223 and sometime 255.
    If I move slow the transmitter-stick , then duty = divf all time, so work perfectly.
    Can somebody explain me whats happen here , please ? I'm very confused..!!
        __config _CONFIG1, _FOSC_INTOSC & _MCLRE_OFF & _CP_ON & _CLKOUTEN_OFF
        __config _CONFIG2, _PLLEN_OFF & _LVP_OFF
    OSCCON = %01101000
    @ ERRORLEVEL -306   ; turn off crossing page boundary message
    include "lcd.bas"
    ADCON0 = %00000000
    ADCON1 = %00000000
    CM1CON0 = 0   ' COMPARATORS OFF
    CM1CON1 = 0
    CM2CON0 = 0   ' COMPARATORS OFF
    CM2CON1 = 0
    CPSCON0 = 0   'CAPACTIVE SENSE MODULE OFF
    RCSTA.7 = 0   'SERIAL PORT OFF
    OPTION_REG.7 = 1 'DISABLE PULL UP
    TRISA  = %00000000
    TRISB  = %00000000
    TRISC  = %00000000
    ANSELA = %00000000
    ANSELB = %00000000
    PORTA  = %00000000
    PORTB  = %00000000
    PORTC  = %00000000
    WPUB   = %00000000
    LATC   = 0
    divf   var byte : divf = 0
    signal var byte
    value  var byte : value =0
    duty   var byte : duty = 0
    gosub lcdrst:pause 300
    pulsin portb.0 , 1 , signal
    if signal > 185 then signal = 185
    if signal > 160 then
        value = (signal - 160) ' value max 25
        lookup value ,[0,30,40,50,65,80,90,100,117,136,153,168,180_
                     ,191,201,209,217,223,233,237,241,244,247,250,255],divf
        divf  = 0
        value = 00
    if duty <> divf then duty = divf
    lcdout $fe, $80 , "Value = " , dec3 value
    lcdout $fe, $C0 , "DUTY =  " , dec3 DUTY
    '-------------------------- LCD -----------------------------
    lcdrst:
    lcdout, $fe, 1
    pause 10
    The first value in the LOOKUP table is returned when value is 0. You have 25 entries in the table so value should range from 0 to 24. When signal is >185 value is 25 which points outside of the table in which case divf remains unchanged - so if this is at startup it remains at 0.
    This I don't think has anything to do with the LOOKUP command. Have you looked at the actual pulses being measured by the PIC, is it possible that they actually ARE varying in widht (due to noise in the stick or whatever) and that the PIC is doing exactly as it should?
    Jan 2014
    Thank you very much for explanation , Henrik....
    The pulses are 100% ok , I verified with a osciloscope,
    Jan 2014
    SOLVED !
    1000 x thanks , HENRIK
    I modified the the loockup table :
    lookup value ,[30,40,50,65,80,90,100,117,136,153,168,180_
                     ,191,201,209,217,223,233,237,241,244,247,250,255,255,255],divf
    OK, are you saying that the randomness when moving the stick quickly is gone as well? I didn't expect that....
    Jan 2014
    Now all are ok !
    Jan 2014
    Now all are ok! The problems was from lookup table, was missing one value.
