Easy Serial to Ethernet module
Results 1 to 7 of 7
    Dec 2005
    Default Re: Easy Serial to Ethernet module
    IMO, ConnectOne's serial <=> ethernet modules are the easiest to use. There's no real low level 'programming' - you merely send AT commands similar to PC-to-modem communication. mackrackit has published example code.
    brighton
    Thanks for your reply
    i check that example out and i think that is what i am looking for
    have anyone got any links of where to get them in the uk
    Best Regards
    Isaac
    Dec 2005
    brighton
    Thank you very much for the link
    it seems to be quite hard to get hold off in the uk but i have sent emails to both distribution listed for the uk
    just keeping my finger grossed at the moment.
    Have anyone else used anything similar ? from the data sheet it seems really easy to use would be a shame
    if we cant get it in the uk
    Isaac
    Dec 2005
    One other plus for Connect One - their serial<->WiFi modules have WPA/WPA2 security and SSL encryption.
