Easy Serial to Ethernet module
Results 1 to 7 of 7
    brighton
    Default Easy Serial to Ethernet module
    Hello Guys
    i need your help is deciding which Serial to Ethernet module that is quite easy to use as there are quite a few out there when i do a search on both this forum and the internet.
    This is basically what i intend to do.............
    I have a Data Logger that store Temperature measurements date stamp etc to a serial eeprom.
    i then go to download this data once in every 3 months with a laptop so i and now thinking that if it might be possible to connect the logger to the internet
    via a Serial to Ethernet module so that i can download this data remotely .
    Would like to hear from anyone who has done anything similar in the past
    Best Regards
    Isaac
    Dec 2005
    Default Re: Easy Serial to Ethernet module
    IMO, ConnectOne's serial <=> ethernet modules are the easiest to use. There's no real low level 'programming' - you merely send AT commands similar to PC-to-modem communication. mackrackit has published example code.
    brighton
    Thanks for your reply
    i check that example out and i think that is what i am looking for
    have anyone got any links of where to get them in the uk
    Best Regards
    Isaac
    Dec 2005
    brighton
    Thank you very much for the link
    it seems to be quite hard to get hold off in the uk but i have sent emails to both distribution listed for the uk
    just keeping my finger grossed at the moment.
    Have anyone else used anything similar ? from the data sheet it seems really easy to use would be a shame
    if we cant get it in the uk
    Isaac
    Dec 2005
    One other plus for Connect One - their serial<->WiFi modules have WPA/WPA2 security and SSL encryption.
    gedass's Avatar
    gedass Guest
    we are using Carambola WiFi module from 8devices company for temperature measurement:
    http://www.8devices.com/wiki_carambo...ambola_pachube
    Carambola WiFi/Ethernet module price begins from 17 EUR only
