PBP and win7
Results 1 to 6 of 6
Thread: PBP and win7
    Default Re: PBP and win7
    The simple explanation is that PBP works fine with Windows-7.
    We would need to know what errors you are getting to give the full explanation.
    Jun 2005
    Up the bush, Western Plains, NSW Au
    G'day Daryl.
    Had another play around with this damn thing and this is what's going on:
    The LCD stuff, straight out of 2.60 manual, with Trisb and Trisc set above the LCD part.
    A small LCD OUT couple of line after the LCDOUT stuff. as below:
    trisb = %00000000
    trisc = %00000000
    Define LCD_DREG PORTc ' Port for LCD Data
    Define LCD_DBIT 0 ' Use upper 4 bits of Port
    Define LCD_RSREG PORTb ' Port for RegisterSelect (RS) bit
    Define LCD_RSBIT 0 ' Port Pin for RS bit
    Define LCD_EREG PORTb ' Port for Enable (E) bit
    Define LCD_EBIT 1 ' Port Pin for E bit
    ;DEFINE LCD_RWREG PORTb (commented out as not using RW)
    ;DEFINE LCD_RWBIT 1 ( ditto )
    Define LCD_BITS 4 ' Using 4-bit bus
    Define LCD_LINES 2 ' Using 2 line Display
    Define LCD_COMMANDUS 2000 ' Command Delay (uS)
    Define LCD_DATAUS 50 ' Data Delay (uS)
    lcdout $fe,1,"Off Hook "
    Hit F9, seems that MPASM starts and the black window opens
    goes straight back to the MCS window with the following in the bottom half of the screen. (These will NOT copy and paste into this answer, or anything else for that matter.
    There are 11 errors:
    Error[113] c:\pbp\pbppic14.lib 2934:Symbol not previously defined(PORTb)
    Error[113] c:\pbp\pbppic14.lib 2935:Symbol not previously defined(PORTb)
    Error[113] c:\pbp\pbppic14.lib 2939:Symbol not previously defined(PORTb)
    Error[113] c:\pbp\pbppic14.lib 2940:Symbol not previously defined(PORTb)
    Error[113] c:\pbp\pbppic14.lib 2950:Symbol not previously defined(PORTc)
    Error[113] c:\pbp\pbppic14.lib 3018:Symbol not previously defined(PORTb)
    Error[113] c:\pbp\pbppic14.lib 3036:Symbol not previously defined(PORTb)
    Error[113] c:\pbp\pbppic14.lib 3060:Symbol not previously defined(PORTb)
    Error[113] c:\pbp\pbppic14.lib 3067:Symbol not previously defined(PORTc)
    Error[113] c:\pbp\pbppic14.lib 3075:Symbol not previously defined(PORTc)
    Error[113] c:\pbp\pbppic14.lib 3076:Symbol not previously defined(PORTb)
    (these have been manually typed as will not copy & paste)
    Using 16F886 for one of those Chipino Pic Arduino things.
    It's enough to make you wanna start using Great Cow Compiler (almost)
    All of this stuff was installed last week from a 2.60 update disk.
    Have just changed to 16F88 with same result.
    Also have had trouble with @DEVICE settings as well, but one thing at a time. I noticed that 2.60 simply will not accept @DEVICE lines.
    So it does seem to me that MPASM is starting up OK , just not doing anything?
    Peter Moritz
    PS I bet it is something simple that I am doing wrong (as always)
    Peter Moritz.
    New South Wales,
    Australia.
    MPASM is case sensitive.
    PORTb should be PORTB
    Jun 2005
    Sh1t, you're bloody kidding me....
    Oh..No you're not..
    That's it!!
    Thanks SO much, I can paste some of my hair back now!
    Peter Moritz.
    New South Wales,
    Australia.
    Quote Originally Posted by muddy0409 View Post
    Hairs?
    Already heard of... but never been able to find some
