I have an external LED board that needs a pin to be pulled to ground to begin its flashing routine. If I connect a wire from ground to this pin it works perfectly.
How would I control this from an output pin of the 16f887? When the pin is high it is +5v, when it is low it is 0v but not ground. Do I need to use an inverter, etc?
Thanks for the help
