Hi Dave,
I was going to suggest the DS30 loader since I've had success with on a 18F25K22. I don't have a 26K22 to play with but what's the problem you're having with it?
Hi Dave,
Well, I went to there website and downloaded all the manuals and the loader files as well as the GUI interface. I have spent all of today trying to get the darn thing to be able to bootload a program. I am trying to use USART1 like normal but no go. I hooked a scope to the TX and RX pins and I did see a character or two returned from the pic 1 time only. I can see the pinging from the pc side but no responces from the pic side. I read a couple of forums and some people have had some success with the USART2 port. I was going to try that next. I have gone over all the spec's for the part and set all the registers to enable the first and second USART ports. I'm at my wit's end... like I said in my request post, I have talked to David Barker, the writer of MicroCode Studio and he has no plans on updating the MicroCode Loader for now. I would think that if you have a product that everybody uses you would support it. I kind of wish Mel Labs would support a bootloader once again. I use it for all my projects from bench to finish products... BTW, I compiled the same program without the asm lines to remap the bootloader location and used MPLAB to load it onto the 18F26K22 and the ports work just fine and as expected.
EN82fn
Hi Dave,
I'm basically in the same boat, I use a bootloader for almost everything where an USART is available, it's just so convenient. Regarding Mecanique, I use MCSP and MCLoader all the time but I'm concidering the product dead - it is what it is and it what's avaialble now is what we'll get.
I seem to remember there was something wrong/weird with the settings for the 25K22, perhaps the same thing applies to the 26K22. I don't remeber exactly where I found the information but here are a couple of links, perhaps you've seen them both, perhaps you haven't.
http://digital-diy.com/forum/chit-ch...ader-t666.html
http://digital-diy.com/forum/amicus-...der-t1300.html
There's also a sample PBP program on the DS30 loader download page.
I placed an Digikey order yesterday, if I'd knew I would include a 26K22....
Good luck and please keep us updated!
In fact Hendrik, The settings.inc file is from an 18F25K22 that was modified. Virtually the same. I am going to try the USART2 port this afternoon and see if it works... I'll keep in touch...
EN82fn
Regarding using 2 serial ports, I have had great success running two ports at different speeds using the 18F26K22. Sample coding below.
Tim.
Code:INCLUDE "DT_INTS-18.bas" ; Base Interrupt System INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler RX1_INT, _SERIALIN1, PBP, no INT_Handler RX2_INT, _SERIALIN2, PBP, no INT_Handler TMR1_INT, _COUNTER, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM RCSTA1 = %11010000 ' Enable 9bit serial port & continuous receive TXSTA1 = %01100100 ' Enable transmit, BRGH = 1 BAUDCON1.3 = 1 ' Enable 16 bit baudrate generator SPBRGH1 = 0 SPBRG1 = B562500 ' 562500 Baud RCSTA2 = %10010000 ' Enable serial port & continuous receive & parity TXSTA2 = %00100100 ' Enable transmit, BRGH = 1 BAUDCON2.3 = 1 ' Enable 16 bit baudrate generator SPBRGH2 = 1 SPBRG2 = B38400 ' 38400 Baud @ 54MHZ
Timmers, I have NO problem using the two ports, in fact, that's why I chose the 18F26K22 for the application. I am running 3 ports, one is DEBUG. The application code is working just fine but it is Annoying to have to remove the part from the product each time to reprogram it when making development changes. I have always used the boot loader with MicroCode Studio, in fact thats why I purchased the product. I used to use the boot loader from Mel Labs but they also decided to stop supporting it a few years ago. Thats why I chose MicroCode Studio as my developement platform. Now that they are showing no interest in supporting the newer Pic's with there product (probably due to lower priority between Proton support, Amicus support and MicroCode studio support) I don't know what to do....
EN82fn
Dave,
This won't help but I always include a ICSP header on my boards so I can connect the PICKit3 and flash the chip if I don't have access to a bootloader.
I'm currently working on a board with a 46K22, I'll see if I can get that going with the DS30 loader but I'm currently having difficulties with the FT232RL USB<->UART bridge (first time using it in my own desing) and I need to get that going before continuing. I know you're using the 26K22 but perhaps it will help you - IF I get it going that is....
