Receiving (Relatively) High Speed Serial Data
Results 1 to 3 of 3
    Nov 2004
    Default Receiving (Relatively) High Speed Serial Data
    Greetings,
    I'm in the beginning stages of a project where one master PIC (likely a 16F88 @ 20 MHz) will be sending serial data to a string of 20-30 12F629s.
    The smaller chips will be running on the internal oscillator @ 4 MHz. And no, they don't have a USART.
    The repeating data stream will consist of a start character and 3-byte 'chunks' for each downstream PIC, ie
    '*', 1A, 1B, 1C, 2A, 2B, 2C, 3A, 3B, 3C ... 29A, 29B, 29C
    Each downstream PIC will be hard-programmed to listen only for data relating to its address, ie 1, 2 or 3... 29
    My question:
    How can I *reliably* get these downstream clockless wonders to receive data at speads greater than 9600 baud? I'd love for them to receive at 19,200 if I can pull it off.
    This would let me update my data stream at a rate of 30 Hz or so...
    Thoughts?
    John
    maybe DEBUG statement can work fine... better than serin or serin2 i think. Don't forget to set the OSCCAL and it suppose to work.
    Jan 2010
    Default Re: Receiving (Relatively) High Speed Serial Data
    Is it possible to Send/Receive data at 9600/19200 with 4MHz internal OSC?
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
