Thanks for all your replies.
1. Mackrackit. Yes, there is a 10k pull-up on the data line.
2. Mr_e. Yes, OSC 32 is in the code.
3. Mr_e. OSC switchover to use a slower internal oscillator - how do you do this?
4. Sayzer. Use a timer interrupt to kill the WHILE. I think this is the best way to go but I'm not clear how to make the interrupt jump over the necessary lines. Can an interrupt direct the execution of the code to a label later in the program? I'd appreciate some advice. I am happy with both PBP and assembler coded interrupts.
The code bit causing the problem is:
If anyone is interested, I'm happy to post all the SHT15 code?Code:' ***************************************************************************** ' * * ' * READ SHT15. Using default setting of 12 bit humidity,14 bit temperature * ' * Because of the WHILE statemets, this hangs if the SHT15 is not conected * ' * * ' ***************************************************************************** ReadSensor: gosub Initialise_SHT15 gosub Start_Sequence shiftout DataPin,Clk,1,[SHTCommand\8] ' Send command byte %0000000011 or %000000101 input DataPin ' Wait for acknowledge low Clk while DataPin = 1 ' Sensor ACK by making Data = 0 wend pulsout Clk,10 ' Send acknowledge while DataPin = 0 wend while DataPin = 1 ' Wait for conversion to complete wend low Clk shiftin DataPin,Clk,0,[RawData.byte1\8] ' Get the first byte, 8 bits low DataPin pulsout Clk,10 ' Send acknowledge shiftin DataPin,Clk,0,[RawData.byte0\8] ' Get the second byte, 8 bits low DataPin pulsout Clk,10 ' Send acknowledge shiftin DataPin,Clk,0,[CRCsensirion\8] ' Get third byte, 8 bits, CRC high DataPin pulsout Clk,10 ' Send acknowledge input DataPin ' End of Transmission input Clk return
Regards Bill Legge
