16F876 : settings for 40Mhz
Results 1 to 20 of 20
    first of all, thanks to steve and melanie for their feedback and help.
    unfortunalety is doesn't work better.
    i have this versions :
    MicroCode Studio Plus 2.1.07
    PicBasic Pro 2.44
    MPASM 3.90 (updated today from 3.50)
    melabs Serial Programmer 3.13 (updated today from 3.10)
    firmware of the programmer 3.5 (updated today from 3.2)
    my code is this :
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H
    DEFINE OSC 40
    led var porta.0
    init:
    clear
    TRISA = %00000000
    PORTA = 0
    high led
    low led
    GOTO main
    in the 18f242.inc file of the pbp root, i set line 20 as follow :
    ; __CONFIG _CONFIG1H, _OSCS_OFF_1H & _XT_OSC_1H
    assembled with MPASM 3.90, getting no errors and no warnings. nothing.
    problem : if i set the osc to 10, it works fine. when i set the osc to 40,
    it works 4 times slower. (i work with a 10 mhz at a 18f242 and capacitors
    with 22pf). in the melabs settings i test hs as osc as well as the hspll.
    both settings have the same effect.
    many thanks for any comment and idea...
    It really looks like your programmer don't set the configuration fuses...
    i don't have any 18F252, but this one is tested with a 18F452
        ' Oscillator switch OFF
        ' Use HSPLL (fosc X 4) oscillator  (10mhz here)
    @ __CONFIG _CONFIG2L, _BOR_ON_2L & _PWRT_ON_2L & _BORV_45_2L
        ' Brown out reset ON @ 4.5Volts
        ' Power-up timer ON
    @ __CONFIG _CONFIG2H, _WDT_ON_2H
        ' Watch dog timer ON
    @ __CONFIG _CONFIG4L, _STVR_ON_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
        ' Stack over/underflow ON
        ' Low Voltage programming OFF
        ' Background debugger OFF
    Define OSC 40
    Start:
          Toggle PORTC.3
          pauseus 100
          goto start
    if you change the DEFINE OSC 40 to DEFINE OSC 10 you'll get 25uSec pulses. So PLL is working very well.
    Look into your Melabs programmer setings, must have a place to configure programmer options.
    If you can't find something like that, send an e-mail to BRUCE from Reynolds Electronics. [email protected] For sure he know the solution for that.
    Default it works
    steve, thanks a lot for the example. this is working very well!
    after that my own example works too. unfortunalety i don't know why... i think it was a configuration at the melabs programmer.
    once again : thanks all for the support
    mischl
    great to know it's working now.
    Have fun!
    With the melabs serial programmer make sure you have these two
    menu options selected.
    Update Configuration From File
    Reread File Before Programming
    This makes sure you are always getting the latest version of the .hex
    file & whatever config word changes you make programmed into the
    target.
    Also, I recommend inserting "every" config word option the target has.
    This way there is no doubt how each option is configured.
    With all of the advanced configuration options the 18F series has, It's in
    your best interest to know exactly how every option is set. Accepting a
    default un-programmed state may cause you problems.
    For the 18F series I comment out every default setting in the PBP device
    header file, and insert my own config fuse settings in my source.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. 16F876 ADCON,CMcon,Tris settings
    Last Post: - 10th March 2010, 21:32
  2. Config settings
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 12th December 2007, 19:24
  3. 16F876 Usart Receive
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 16:43
  4. Changing Settings ???
    By tico in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 04:10
  5. Need help with migration 16F876 -> 18F252
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 24th February 2004, 17:22
