16F876 : settings for 40Mhz
Results 1 to 20 of 20
    NOP.... Read the bottom of your .inc file. you must write...
    @ __CONFIG _CONFIG1H, _HSPLL_OSC_1H
    DEFINE OSC 40
    what about now
    first i got two error messages about "overwriting previous address content" which i fixed with comment out the line "_CONFIG1H......" in 18F242.inc from the PBP root.
    for testing i work with a simple programm which blinking a led. it works..., but the pause command is 4 times slower then it should be. so, it seems the pic works with the 10mhz from the external oscillator, not with the 40mhz i wish.
    in the melabs programmer i've set the oscillator to HS as HSPLL too for testing, the result is the same. what can be wrong again?
    thanks a lot for a support
    That's strange. I'm not 100% of what i say but, looks like your programmer don't program the configuration bits for your device.
    What's happening if you use a 20 MHZ oscillator and use HS mode???
    what about now if you use a 4mhz and and use XT mode???
    Whether you set the config bits in your program or not, you should be capable of setting those bits manually prior to burning the PIC. If your programmer is incapable of doing that, you may need a sortware update for it, or alternatively you might need a better programmer.
    that's for sure Melanie. But i think you can setup Melabs programmer to write configuration bits or not... i'm really not sure of what i say. Maybe some EPIC user or Bruce can second this ?
    first of all, thanks to steve and melanie for their feedback and help.
    unfortunalety is doesn't work better.
    i have this versions :
    MicroCode Studio Plus 2.1.07
    PicBasic Pro 2.44
    MPASM 3.90 (updated today from 3.50)
    melabs Serial Programmer 3.13 (updated today from 3.10)
    firmware of the programmer 3.5 (updated today from 3.2)
    my code is this :
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H
    DEFINE OSC 40
    led var porta.0
    init:
    clear
    TRISA = %00000000
    PORTA = 0
    high led
    low led
    GOTO main
    in the 18f242.inc file of the pbp root, i set line 20 as follow :
    ; __CONFIG _CONFIG1H, _OSCS_OFF_1H & _XT_OSC_1H
    assembled with MPASM 3.90, getting no errors and no warnings. nothing.
    problem : if i set the osc to 10, it works fine. when i set the osc to 40,
    it works 4 times slower. (i work with a 10 mhz at a 18f242 and capacitors
    with 22pf). in the melabs settings i test hs as osc as well as the hspll.
    both settings have the same effect.
    many thanks for any comment and idea...
    It really looks like your programmer don't set the configuration fuses...
    i don't have any 18F252, but this one is tested with a 18F452
        ' Oscillator switch OFF
        ' Use HSPLL (fosc X 4) oscillator  (10mhz here)
    @ __CONFIG _CONFIG2L, _BOR_ON_2L & _PWRT_ON_2L & _BORV_45_2L
        ' Brown out reset ON @ 4.5Volts
        ' Power-up timer ON
    @ __CONFIG _CONFIG2H, _WDT_ON_2H
        ' Watch dog timer ON
    @ __CONFIG _CONFIG4L, _STVR_ON_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
        ' Stack over/underflow ON
        ' Low Voltage programming OFF
        ' Background debugger OFF
    Define OSC 40
    Start:
          Toggle PORTC.3
          pauseus 100
          goto start
    if you change the DEFINE OSC 40 to DEFINE OSC 10 you'll get 25uSec pulses. So PLL is working very well.
    Look into your Melabs programmer setings, must have a place to configure programmer options.
    If you can't find something like that, send an e-mail to BRUCE from Reynolds Electronics. [email protected] For sure he know the solution for that.
  1. 16F876 ADCON,CMcon,Tris settings
    Last Post: - 10th March 2010, 21:32
  2. Config settings
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 12th December 2007, 19:24
  3. 16F876 Usart Receive
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 16:43
  4. Changing Settings ???
    By tico in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 04:10
  5. Need help with migration 16F876 -> 18F252
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 24th February 2004, 17:22
