Subroutine placement - must they come first?
Results 1 to 7 of 7
    Default Subroutine placement - must they come first?
    In any new program I first have any DATA statements, then I declare the hardware assignment then the software variables and follow that with subroutines. I jump over the subroutines to get to the Initialise block and then get to MAIN where the program code loops as it runs.
    Must it be this way? Can I place all the subroutines at the very end of the program? This would make the code easier to read in some cases.
    Cheers
    BrianT
    Default Re: Subroutine placement - must they come first?
    If you're using a 16F part, your code is relatively small, and all fits into code page 0 with PBP library code, it doesn't matter where you place your subroutines.
    As your code grows beyond code page 0 it might matter where you place them. All PBP library code has to fit into code page 0 on 16F type parts. If your program extends into page 1, and your subroutines are on page 1, then it takes more code to switch back & forth between code pages.
    If your subroutines all fit into page 0, and your main routine ends up in page 1, it will save code space because your subroutine calls to PBP library code are on the same code page 0.
    I normally put a large number of subroutines in an include file so I don't have to scroll through them all to work on code in my main loop.
    GOTO Main
    INCLUDE "MySubs.INC"
    Call subs from here.
    GOTO Main
    If all my subroutines won't fit into code page 0.. I'll try to get the ones used most often - or the ones with the most library calls squeezed in.
    You can experiment with shifting code around to see the difference.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    One good thing to remember about asm DATA, DA, DT...
    Recently I've messed a lot with the Nokia GLCD thing and while I added Strings, some could not be properly displayed, code went to lalaLand. The reason is like Bruce said... page boundary. In the end my macro just needed a simple modification... from something like
    MyWhateverString Macro Str
               local STRStart, STREnd
               GOTO STREnd
    STRStart
               DT Str
    STREnd
               MOVE?CW STRStart, _WhateverAddrVar
               L?CALL _MainSub
               ENDM
    To
               L?GOTO STREnd
    STRStart
               DT Str
    STREnd
               L?CALL _MainSub
          ENDM
    problem solved
    Oh Steve, that was Your code I saw . . .
    A snip of...few hundred lines....
    My ignorance is on clear display here so please be gentle.
    I have a system of two PIC16F88 and three 18F4620 which all chatter amongst themselves over a multiwire parallel bus. Some of the code takes up over 63000 bytes on a PIC 18F4620.
    Currently all the subroutines are placed after the hardware and variable declarations. I would like to have the subroutines at the bottom of the code if possible for simpler reading.
    I recall some earlier (PBP2.xx?) comments that subroutines should be at the top of the program but is there any more explicit advise for the 16F88 or the 18F4620. Bruce's comments pass over my head.
    Cheers
    BrianT
