Hi Bob,
(EDIT: sayzer beat me to it but I'll post this anyway)
Several ideas....but they depend a bit on how you have the thyristors connected to the PIC. The "best" would be if they where connected to consecutive pins on a port, like PortC.0 to PortC.5 or PortB.2 to PortB.7 etc.
Without knowing that, here's one way. Create an index variable or "pointer" if you like that you cycle thru 0,1,2,3,4,5 or 5,4,3,2,1,0 depending on direction. Then use a SELECT CASE statement with your index variable and 6 different cases, all quite similar to each other but with the different thyristors firing. But use a FOR-NEXT loop instead of 5 discrete on-off pulse cycles. Something like this:
Index VAR BYTE
Fire VAR BYTE
Direction VAR BYTE
Forward CON 1
Reverse CON 255
Direction = Forward
Select Case Index
Case 0
For Fire = 0 to 4
High Thy1
High ThY5
PauseUs 200
Low Thy1
Low Thy5
PauseUs 200
NEXT
Index = Index + Direction
If Index = 255 then Index = 5 ' We're going backwards, start over at step 5
Case 1
For Fire = 0 to 4
High Thy1
High Thy6
PauseUs 200
Low Thy1
Low Thy6
PauseUs 200
Next
' Case 2,3 and 4 all similar to Case 1
Case 5
For Fire = 0 to 4
High Thy3
High Thy5
PauseUs 200
Low Thy3
Low Thy5
PauseUs 200
Next
If Index = 6 then Index = 0 ' We're going forward, start over at step 0
END SELECT
All untested code but I hope it can serve as a starting point. If you do have the thyrsitor across a single port then a lookup table and a single FOR-NEXT loop can replace the above.
HTH,
