Having all sequences stored in eeprom and reading them from there would make it much shorter.
for example:
read Index,PosX             ' Read all sequences from eeprom, previously arranged manually.
Read (Index+100),PauseVal    ' Read required delay time stored in eeprom (in case the delay time is different for each sequence).
Thy1 = PosX.0               ' Assign thyristor distribution.
Thy2 = PosX.1
Thy3 = PosX.2
Thy4 = PosX.3
Thy5 = PosX.4
Thy6 = PosX.5
pauseus PauseVal            ' Delay for required time.
index = index + 1           ' Increment the sequence index.
if index = ENDOFSEQ then index = 0   ' Reached the end of sequence. Loop over.
This is just an example.
You may change it as you like.
Just have all on-off sequence and delay time(s) stored in eeprom and read from there.
