fuses
Results 1 to 2 of 2
Thread: fuses
    Sep 2006
    Venezuela - Caracas
    Default fuses
    i need work with PIC18F14K50 with 8mhz resonator
    asm
    __CONFIG _CONFIG1L, _CPUDIV_CLKDIV2_1L & _USBDIV_ON_1L
    __CONFIG _CONFIG1H, _FOSC_HS_1H & _PLLEN_ON_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    __CONFIG _CONFIG2L, _PWRTEN_ON_2L & _BOREN_ON_2L & _BORV_22_2L
    __CONFIG _CONFIG2H, _WDTEN_OFF_2H
    __CONFIG _CONFIG3H, _MCLRE_OFF_3H
    __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    __CONFIG _CONFIG5L, _CP0_ON_5L & _CP1_ON_5L
    __CONFIG _CONFIG5H, _CPB_ON_5H
    endasm
    define osc 32
    config not work
    ..: Don't worry, be happy :..
    Default Re: fuses
    When you say "not work"... does a simple led blinky with PAUSE 1000 work slower, faster... or not at all?
    what about if you use DEFINE OSC 32 in UPPERCASE?
