1 Continuous MCPWM at a time
Results 1 to 40 of 47
    Default Re: 1 Continuous MCPWM at a time
    Almost impossible to say although noise on the MCLR pin or supply lines are likely causes. There's a register, I believe it's called RCON (check the datasheet), which you can check to see what caused the reset. There will be various bits set depending on if it was a brown-out reset etc - that might help.
    Make sure you have sufficient decoupling as close to the supply pins as possible and make sure you coonect ALL the supply pins - not just one pair.
    Mar 2006
    China
    Add some capacitors to the MCLR. Maybe 0.1 uF and 2.2uF and hopefully you can still program the pic. If you have a long trace on the pcb to the programming connector you can also try to add the capacitors close to the connector since that trace will act like an antenna.
