Hello,
Thank you for your reply,
The IF...THEN code still works (thanks for the tip putting just the subroutines at the top of main).
I am only using a PICkit 2 programmer. ?!Do you have a serial connection setup? If so you can HSEROUT some debug information which will make it easier to figure out what's going on.
What do you mean ??If not perhaps you could blink a LED the same number of times as the value that gets assigned to EncoderState1, just to see what's going on.
This morning I've tried a different code :
In case 0, it is doing what it should do, now if I'm trying to give the value of 1 (I have a switch on portA.0, that is all !!) it jumps to case else, it means that it does not see the value 1 ??? Why not ? it is working with IF... THEN...Code:Main: encoderstate1 = PORTA Select encoderstate1 Case %000000 GoSub GetADC GoSub SetPWM OVDCOND = %00100010 'Q4 (PWM5) and Q10 (PWM1) PORTC = %00000011 'Q1 and Q7 ON Case %000001 GoSub GetADC GoSub SetPWM OVDCOND = %00100010 'Q4 (PWM5) and Q10 (PWM1) PORTC = %00000011 'Q1 and Q7 ON Case Else PORTC = 0 OVDCOND = 0 EndSelect
Moreover, after switching my switch and giving the value 1 to portA.0, 4seconds after, it acts like if the value on portA.0 was 0... ???
AHHH sometimes those pics know how to make you crazy, doesn't they ?
Thanks for the help. Very much appreciated![]()
