When using HSERIN/HSEROUT, you MUST use DEFINE.
Then why does this work?
'18F6680   02/14/09  INFEED PARSE TEST BAUD 9600
    DEFINE OSC 20
    @ __CONFIG    _CONFIG1H, _OSC_HS_1H
    @ __CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
    @ __CONFIG    _CONFIG4L, _LVP_OFF_4L
    DEFINE LCD_DREG     PORTG
    DEFINE LCD_DBIT     0
    DEFINE LCD_RSREG    PORTE
    DEFINE LCD_RSBIT    0
    DEFINE LCD_EREG     PORTE
    DEFINE LCD_EBIT     1
    DEFINE LCD_BITS     4
    DEFINE LCD_LINES    4
    DEFINE LCD_COMMANDUS    3000
    DEFINE LCD_DATAUS   150
    DEFINE HSER_EVEN
    PAUSE 100 : LCDOUT $FE,1,"TEST"
    N1 VAR LONG:N2 VAR LONG
    START: N1 = 0 : N2 = 0
    HIGH PORTG.4 :PAUSE 250:LOW PORTG.4
    RCSTA.4 = 0 : RCSTA.4 = 1
    'CHANGE LINE FEED AND CARRIAGE RETURN AS REQUIRED
    RCSTA=$90:TXSTA=$24:SPBRG=129:HSERIN[WAIT($a),WAIT($d),DEC N1,WAIT(","),DEC N2]
    LCDOUT $FE,1,DEC N1 : lcdout $FE,$C0,DEC N2 : GOTO START
