Using all the information found here on the forums (thanks to all that help answer questions on the forum) we have a working SERIN2 program. We would like to convert the program to HSERIN to hopefully gain efficiency, and possibly use the On Interrupt. (i.e. http://melabs.com/resources/samples/x1/pbp/serbufx.htm)
Unfortunately we have been unable to receive any characters using HSERIN, but SERIN2 works great. HSEROUT also works great.
This line works great...
SerIn2 GPSin,baud19200,Timeout,Nostring,[WAIT("$GPRMC,"),dec2 gpsutctimehh,DEC4 gpsutctimemmss,skip 1,dec3 gpsmsec,skip 1,GPSstatus,skip 28,dec4 GPSspeed,skip 1,dec2 gpsspeedtenth,skip 1, dec3 gpscourse,skip 1, dec2 gpscoursetenth]
This line returns nothing but zeros (0)...
hserin Timeout,Nostring,[WAIT("$GPRMC,"),dec2 gpsutctimehh,DEC4 gpsutctimemmss,skip 1,dec3 gpsmsec,skip 1,GPSstatus,skip 28,dec4 GPSspeed,skip 1,dec2 gpsspeedtenth,skip 1, dec3 gpscourse,skip 1, dec2 gpscoursetenth]
Is HSERIN more involved than what I have shown in the below example (two examples shown, one SERIN and one HSERIN)? The HSEROUT works great, just as we would expect, but HSERIN receives nothing.
Here is the entire working version with SERIN...
'*********Constants, Variable and Defines***************
' Setup Chip Oscillator This is also in the .INC file provided by MeLabs and
' Needs to be comminted out in the MeLabs .INC file (C:\PBP\18f2420.inc)
'Oscillator system clock switch and Oscillator Selection bits
@ __CONFIG _CONFIG1H, _OSC_HS_1H
'Brown-Out Reset & Brown-out Reset enabled in hardware only (SBOREN is disabled) & 3.2 volt Minimum setting
@ __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOREN_SBORDIS_2L & _BORV_3_2L
'Watchdog Timer Enable and Timer Postscale Select bits
@ __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
'CCP2 input/output is multiplexed with RC1 & PORTB<4:0> pins are configured as digital I/O on Reset &
'Timer1 configured for higher power operation & MCLR pin enabled; RE3 input pin disabled
@ __CONFIG _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
'Stack full/underflow will cause Reset & Single-Supply ICSP disabled & Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
@ __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
' SETUP CHIP CLOCK SPEED
DEFINE OSC 10
'pinouts for Serout2 commands:
GPSin VAR PORTC.7 ' GPS transmit, PIC recieve pin
TRISC.7 = 1 ' Set PORTC, pin 1 to an input
GPSout var PORTC.6 ' GPS recieve, PIC transmit pin
TRISC.6 = 0 ' Set PORTC, pin 6 to an output
CSpic VAR PORTB.1 ' SPI "Chip Select PIN"
TRISB.1 = 1 ' Set PORTB, pin 1 to an input
PICout var portC.5 ' Pic Serial Data Output pin
'Allocate Constants for Serial Com
TimeOut CON 3 'Serial port input time out
baud9600 CON 84 '9600 baud
baud19200 con 32 '19200 baud Driven True None 32
'Allocate Variables for GPS:
knots VAR WORD 'Calculated knots
fps VAR WORD 'Feet Per Second Calculated
fpm VAR WORD 'Feet Per Minute Calculated
GPSUTCtimehh var byte 'GPS UTC Time hh (hhmmss.sss)
GPSUTCtimemmss var word 'GPS UTC Time mmss (hhmmss.sss)
GPSmsec var word 'GPS UTC sss (hhmmss.sss)
GPSStatus var byte 'GPS Status string V = 86 = Nav Receiver Warning; A = 65 = Data Valid
GPSSpeed var word 'GPS Speed over ground
GPSSpeedtenth var byte 'GPS Speed over ground tenths
GPSCourse var word 'GPS Course over ground
GPSCoursetenth var byte 'GPS Course over ground tenths
fpm = 0
ADCON1 = 15 'Set all pins as digital on PIC18F2420
high picout 'needed to start the serout communication, if we don't idle the PICout line high then the serin on the other pic hangs
pause 3000 'wait for GPS module to turn on before sending commands
' Setup Hardware Serial Input, use instead of defines, so it can be changed
'RCSTA = $90 ' Enable serial port & continuous receive
'TXSTA = $24 ' Enable transmit, BRGH = 1
'SPBRG = 64 ' 9600 Baud @ 0.16%
'Setup Serial Port Baud rate to 19200 from 9600
serout2 GPSout,baud9600,[$A0, $A1, $00, $04, $05, $00, $02, $00, $07, $0D, $0A]
'hserout [$A0, $A1, $00, $04, $05, $00, $02, $00, $07, $0D, $0A]
pause 1500
'RCSTA = 0 ' Disable serial port & continuous receive
'SPBRG = 32 ' 19200 Baud @ -1.36%
'Setup NMEA Message to only send RMC - Recommended Minimum Specific GNSS Data, turn all other messages off
serout2 GPSout,BAUD19200,[$A0, $A1, $00, $09, $08, $00, $00, $00, $00, $01, $00, $00, $00, $09, $0D, $0A]
'hserout [$A0, $A1, $00, $09, $08, $00, $00, $00, $00, $01, $00, $00, $00, $09, $0D, $0A]
pause 1500
'Setup the Position Rate of GPS module TO 5Hz
serout2 GPSout,BAUD19200,[$A0, $A1, $00, $03, $0E, $05, $00, $0B, $0D, $0A]
'hserout [$A0, $A1, $00, $03, $0E, $05, $00, $0B, $0D, $0A]
pause 3000
GPS:
'hserin Timeout,Nostring,[WAIT("$GPRMC,"),dec2 gpsutctimehh,DEC4 gpsutctimemmss,skip 1,dec3 gpsmsec,skip 1,GPSstatus,skip 28,dec4 GPSspeed,skip 1,dec2 gpsspeedtenth,skip 1, dec3 gpscourse,skip 1, dec2 gpscoursetenth]
NoString: 'if no data is receivd we still need to continue through rutine
knots = gpsspeed * 100 + gpsspeedtenth
fps = (knots * 169)/10000 'knots * 1.68781 = fps
fpm = (knots * 101)/100 'knots * 101.2686 = fpm
'fpm = fpm + 1 'used for testing
if CSpic = 0 then goto gps
serout2 picout,baud19200,[dec5 gpsstatus]
goto GPS
EndError:
Here is the HSERIN version, it only receives zeros...
DEFINE OSC 10
'GPSin VAR PORTC.7 ' GPS transmit, PIC recieve pin
'TRISC.7 = 1 ' Set PORTC, pin 1 to an input
'GPSout var PORTC.6 ' GPS recieve, PIC transmit pin
'TRISC.6 = 0 ' Set PORTC, pin 6 to an output
fpm = 0
'serout2 GPSout,baud9600,[$A0, $A1, $00, $04, $05, $00, $02, $00, $07, $0D, $0A]
pause 1500
'serout2 GPSout,BAUD19200,[$A0, $A1, $00, $09, $08, $00, $00, $00, $00, $01, $00, $00, $00, $09, $0D, $0A]
pause 1500
'serout2 GPSout,BAUD19200,[$A0, $A1, $00, $03, $0E, $05, $00, $0B, $0D, $0A]
pause 3000
GPS:
'SerIn2 GPSin,baud19200,Timeout,Nostring,[WAIT("$GPRMC,"),dec2 gpsutctimehh,DEC4 gpsutctimemmss,skip 1,dec3 gpsmsec,skip 1,GPSstatus,skip 28,dec4 GPSspeed,skip 1,dec2 gpsspeedtenth,skip 1, dec3 gpscourse,skip 1, dec2 gpscoursetenth]
goto GPS
EndError:
Rodney
