16F877A - problem with Port D
Results 1 to 2 of 2
    Default 16F877A - problem with Port D
    Hello, I am working with 16F877A which Serin some signal and put it's ports high or low. I have 4 LED's on Port B (7,6,5,4) & 4 LED's on Port D(7,6,5,4).
    The one on PortD are being funny. They are not responding to the inputs. Not going high or low. I am using DT_Int in the code as well. My config values are as follows:
    Include "modedefs.bas"
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
    @ __Config _XT_OSC & _WDT_OFF & _PWRTE_ON & _BODEN_ON & _LVP_OFF & _CP_ALL & _CPD_ON
    Pause 50
    wsave VAR BYTE $70 SYSTEM
    '-------------------------FUSES SET----------------------------
    PAUSE 50
    ADCON1=7
    CMCON=7
    CCP1CON=0
    OPTION_REG=%10000000
    TRISA=0 : PORTA=0
    TRISE=0 : PORTE=0
    TRISB=0 : PORTB=0
    TRISC=%10000000 : PORTC=0
    TRISD=0 : PORTD=0
    @ ERRORLEVEL -306
    Is something wrong with my fuse settings, rest everything seems fine to me.
    ___________________
    WHY things get boring when they work just fine?
    Default Re: 16F877A - problem with Port D
    Nothing wrong or special with PORTD on this one. Config fuses seems fine. Something's wrong somewhere in your whole code.
