PIC problem !!!
Results 1 to 8 of 8
Thread: PIC problem !!!
    Feb 2007
    Default PIC problem !!!
    Hi all,
    I wrote a program using PBP250C for the 16F877A
    i am using the ICSP to program the PIC, everything is working properly, i can write and read the PIC, but sometimes when trying to read the program via the ICSP, after reading it, the PIC stops running and i should reprogram it again, as if it becomes erased !!!
    i don't know what's happening, the hardware is correct, it is not the first time that i am using the ICSP, i can share the PCB if it is necessary.
    Anyone can help ???
    Thank you
    Aug 2010
    Maryland, USA
    Default Re: PIC problem !!!
    Maybe it's a MCLR issue?
    -Bert
    Miami, Florida USA
    Rony,
    There are many things that can cause that problem. If we can see the schematics it would help. There is some help here for the melabs programers,
    http://melabs.com/support/icsp.htm
    Anonymous
    Feb 2007
    This is the PCB capture, thanks
    Feb 2007
    With "DIP Switch"
    Feb 2007
    PORTB is internally puled up,
    i switched ON pin 4 in the DIP switch (RB3 to zero) and still having the same problem
    Mar 2006
    China
    I have never liked the 16F877A pic. When I used it I always had resets and other strange issues so I just changed to 18F452 or 18F4620 which are both pin-compatible with the 877A and not that much more expensive.
    Just make sure the LVP (low voltage programming) is turned off in the config bits.
    Sometimes I rather have a working product than really understanding why it doesnt work.
    With the BIG caps on your board something Hurts me :
    14.5 Power-on Reset (POR)
    A Power-on Reset pulse is generated on-chip when
    V
    DD rise is detected (in the range of 1.2V-1.7V). To take
    advantage of the POR, tie the MCLR pin to V
    DD
    through an RC network, as described in
    Section 14.4
    “MCLR”
    . A maximum rise time for VDD is specified.
    See
    Section 17.0 “Electrical Characteristics” for
    details.
    When the device starts normal operation (exits the
    Reset condition), device operating parameters (voltage,
    frequency, temperature, etc.) must be met to
    ensure operation. If these conditions are not met, the
    device must be held in Reset until the operating conditions
    are met.
    looks there's a missing cap in your design ... don't you think ???
    On my side, I use MC34064P5 supervisor to get rid of power on or reset rise times ... and have NO issues with reset pin ...
    BTW ... a hardware reset after reading the Prog memory is not to forget ...
