Oh, I see. OK, but take into account what I noted on the post.
It is slow and may oscillate. I am sure it will. Also depending on the resolution, the dead band may be large. Of course the larger it is the less it will oscillate.
I wrote this :
but the heating start ONLY when w1 < (calibra - 3) !Code:if w1 < (calibra - 3) then pwm mosfet 155, 250 if w1 < (calibra - 1) then pwm mosfet 100, 200
Why don't start when w1 < (calibra - 1) ?!?
Example : if calibra (value for memory, set by user) is 140, the heating start at 137.
I wrote the routine for display those two values : w1 (current temperature) and calibra. The led blink ( PWM out) only when w1 < ( (calibra-3) !
Code:if mode = 2 then call poz char = 16 call PrintChar calibra = vt LcdReg = %10000000 + 25 ' cursor X call PrintCtrlLcd LcdReg = %01000011 + 1 ' cursor Y call PrintCtrlLcd '~~~~~~~~~~~~~~~~~ now display results if (vt dig 2) <1 then char = 16 call Printchar else Char = (vt dig 2) call PrintChar endif Char = (vt dig 1) call PrintChar Char = (vt dig 0) call PrintChar Char = 16 call PrintChar Char = 13 call PrintChar Char = 14 call PrintChar Char = 16 call PrintChar Char = 15 call PrintChar endif
Fratello,can you make a code with MAX6675 thermocouple cold junction sensor?I have one,so I want to use it.
Here, I'm familiar with the MAX6675 so I'll give you a start...
This should read the MAX6675 and display degrees C & degrees F on a LCD display.
(Pin aliases for LCD not shown, only for the MAX6675)
Code:'Alias pins - MAX6675 temp sensor MXSCLK var PORTD.0 'MAX6675 Clock MXCS var PORTD.2 'MAX6675 Chip Select MXSO Var PORTD.3 'MAX6675 Serial Data '--Variables----------------------- kTemp var word 'raw data from MAX6675 tempC var word 'temperature in degrees C tempF var word 'temp C converted to degrees F '-----------Read and display temperature from MAX6675----------- main: LOW MXCS 'chip select low shiftin MXSO, MXSCLK, 0, [kTemp\16] 'shift in the data HIGH MXCS 'chip select high tempC = kTemp >> 5 'side shift to ditch the stuff to the right of the decimal point and just show whole degrees) tempF = ((tempC * 18)/10) + 32 'convert C to F lcdout $fe,1,dec tempC," degrees C ",$fe,$c0,dec tempF," degrees F " 'display the data on LCD pause 500 goto main end
So it's possible to write code for 16F628A (16F648A), for example...since 12F675 don't have enough ports. And working with large fonts (if using Nokia LCD disply) , memory, pre-setting, etc...
