314 words is the size when compiled by itself. Depending on what functions your code uses it might already have one or more of the PBP library routines included meaning the total size will be less than whatever + 314 words.
But like I said, the problem in this case is likely the amount of available RAM. If my count is correct your code uses 23 bytes and the original incPID uses 29 bytes, then, if I'm not mistaken, PBP adds ~24 bytes for its internal use (might change depending on what library routines are used, I don't know for sure). All in all this adds up to more than the 64 bytes of RAM available on the 12F675.
What I meant with not being worth it wasn't that you should throw a "bigger" PIC at the issue. I meant that I don't think the effort of implementing incPID is worth it considering the performance gain you might get compared to the aproaches already discussed. Sure, it it fits it's wort a try, if it doesn't fit I'd try to make do with what's available.
Finally incPID was written in order to be versatile and easy to use. It's probably possible to reduce the size and amount of RAM needed further if adapting it to a specific application - but that's up to anyone using it to do.
