Soldering station
Results 1 to 38 of 38
    Default Re: Soldering station
    FTR, Nokia 3310 or 5110 are basically the same. they use PCD8544 controller. Seems there's no longer a load of 1-2$ deal 'round here... probably because they are so popular
    A fullblown PID is probably overkill but, for the record, incPID_mc is the multichannel version of the PID-filter. It works fine with a single channel but it takes a lot more codespace than the original incPID routine.
    You can find v1.5 of the single channel version in this post. And with THAT said it still won't fit the 12F675 due to the limited amount of RAM available in that device.
    What I'd do is probably something in the line of what Jerson showed but I'd also add a bias or feedforward based on the setpoint (not the error). If you know that in order to maintain a temperature of say 250°C you need a dutycycle of 40% then, once you're within the window of the regulator you enable the P(I) regulator and add the bias/feedforward to the output.
    You'll need to work out a suitable bias/feedforward "gain" since it's not going to be perfectly linear. Since the system (probably) heats up faster than it cools down and you can't have "negative drive" you should err on the low side for the bias/feedforward so that IT alone can never drive the temp OVER the setpoint. If it does the regulator can't bring it down since it can never go "below" 0% PWM.
    EDIT: The original version of incPID, which can be found i post 1 in the thread above, compiles to 314 words on the 12F675 and uses 29 bytes of RAM. Depending on how many bytes of RAM your application uses it MIGHT fit but again, it's probably not worth it.
    Hello Henrik,
    Probably not in Sweden or the USA, but in Romania, it might be very well worth it. Import tax is high there, wages not so much . . . Thanks for helping him.
    JS
    Dec 2008
    Ploiesti, ROMANIA
    Thanks to all for support !!! Glad to see people helping others...
    I will take attention to inc_PID, but ... now my code is 1002 words . The best (so far) solution it's to "upgrade" the PIC (maybe 18F...) but, for moment, I will try to keep this "low-cost variant".
    Try to compact your code. Maybe repeated code can be a subroutine etc.
    Also if you use flags, then declare them as BIT and not as BYTE or even worse as WORD.
    If you need a BYTE variable, do not declare as WORD.
    Dec 2008
    Ploiesti, ROMANIA
    Whitout "graphics elements" the code it's 659 words. Maybe it's a good start for use PID ?! (+314 words)
    ' version 2
    @ DEVICE PIC12F675, intrc_osc_noclkout, wdt_off, mclr_off
    DEFINE OSC  4
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    CMCON    = 7
    TRISIO   = %001001
    INTCON   = 0
    GPIO     = 0
    ANSEL    = %00010001
    ADCON0   = %10000001
    wpu      = %00000010
                D_C      var     GPIO.2
                SDIN     var     GPIO.4
                SCK      var     GPIO.5
                MOSFET   var     GPIO.1
              buton    var     GPIO.3
                LcdReg          var  byte
                x               var  byte
                y               var  byte
                z               var  byte
                a               var  byte
                PosX            var  byte
                PosY            var  byte
                Chr             var  byte
                LcdData         var  byte
                Offset          var  byte
                Char            var  byte
                adval           var  word
                w1              var  word
              vt              var  word
              cnt             var  byte
                grup            var  word
                mode               var  byte
              calibra         var  word
                DATA @0,$3E,$51,$49,$45,$3E,_       ';// 0
                        $00,$42,$7F,$40,$00,_       ';// 1
                        $42,$61,$51,$49,$46,_       ';// 2
                        $21,$41,$45,$4B,$31,_       ';// 3
                        $18,$14,$12,$7F,$10,_       ';// 4
                        $27,$45,$45,$45,$39,_       ';// 5
                        $3C,$4A,$49,$49,$30,_       ';// 6
                        $01,$71,$09,$05,$03,_       ';// 7
                        $36,$49,$49,$49,$36,_       ';// 8
                        $06,$49,$49,$29,$1E,_       ';// 9
                        $08,$08,$3E,$08,$08,_       ';// +
                        $08,$08,$08,$08,$08,_       ';// -
                        $00,$60,$60,$00,$00,_       ';// .
                        $00,$02,$05,$02,$00,_       ' grad
                        $3E,$41,$41,$41,$22,_       ' C
                        $7F,$02,$0C,$02,$7F,_       ' M
                        $00,$00,$00,$00,$00,_       ' space
                     $08,$04,$7F,$04,$08,_       ' arrow up
                        $20,$40,$7F,$40,$20         ' arrow down
               LcdReg  =  %00100001         'LCD Extended Commands.
               call    PrintCtrlLcd
               LcdReg  =  $E6               'Set LCD Vop (Contrast).Initial $C5
               call    PrintCtrlLcd
               LcdReg  =  %00000110         'Set Temp coefficent.
               call    PrintCtrlLcd
               LcdReg  =  %00010011         'LCD bias mode 1:48.
               call    PrintCtrlLcd
               LcdReg  =  %00100000         'LCD Standard Commands
               call    PrintCtrlLcd
               LcdReg  =  $0C               'LCD in normal mode.  $0D inverse
               call    PrintCtrlLcd
    Pause 100
    Call CursorHome
    Pause 100
    Gosub LCD_Clear
    mode = 0
    Pause 500                ' time to give-up :)
    '===================== READING VOLTAGE ==============================
    low mosfet
     vt=0
     grup=0
         for cnt = 1 to 20
     ADCON0.1 = 1
     WHILE ADCON0.1 = 1 : WEND
     Pause 10
     adval.HighByte = ADRESH
     adval.LowByte = ADRESL
     PAUSE 10
         vt=adval * 500
         vt=div32 1023
         grup=vt+grup
     PAUSE 10
         next cnt
     w1=grup / 20
    '~~~~~~~~~~~~~~~~~ setting cursor for display the voltage
                    LcdReg  =  %10000000 + 25        ' cursor  X
                    call    PrintCtrlLcd
                    LcdReg  =  %01000011             ' cursor  Y
                    call    PrintCtrlLcd
    '~~~~~~~~~~~~~~~~~ now display results
     if (w1 dig 2) <1 then
                    char = 16
                    call Printchar
                    Char = (w1 dig 2)
                    call    PrintChar
                    Char = (w1 dig 1)
                    call    PrintChar
     if (w1 dig 0) < 5 then
                    Char = 0
                    call    PrintChar
                    char = 5
                    call PrintChar
                    Char = 16
                    call    PrintChar
                    Char = 13
                    call  PrintChar
                    Char = 14
                    call  PrintChar
    if buton = 0 then
    mode = mode + 1
    gosub memo
    gosub check
    Pause 100
    Goto Main
    '================== L C D ===========================================
    CursorHome:     LcdReg  =  %10000000            ' cursor Home
                    call    PrintCtrlLcd
                    LcdReg  =  %01000000            ' cursor Home
                    call    PrintCtrlLcd
    PrintChar:      offset = Char * 5
                    for a = 1 to 5
                        read offset, LcdReg
                        call  PrintDataLcd
                        offset = offset + 1
                    next a
                    LcdReg = 0
                    call    PrintDataLcd
    PrintCtrlLcd:   D_C = 0
    PrintDataLcd:   for x = 1 to 8
                        SDIN = LcdReg.7
                        SCK = 1
                        LcdReg = LcdReg << 1
                        SCK = 0
                    next x
                    D_C = 1
    LCD_Clear:
                    PosX=0:PosY=0:Gosub LCD_GotoXY
                    D_C = 1
                    FOR Chr=1 TO 252
                        LcdData=0:Gosub LCD_ByteOut
                    next Chr
    LCD_GotoXY:
                    D_C = 0
                    LcdData=%01000000 | PosY :Gosub LCD_ByteOut
                    LcdData=%10000000 | PosX :Gosub LCD_ByteOut
    LCD_ByteOut:
                    SHIFTOUT SDIN,SCK,1,[LcdData]
    memo:
    if mode = 1 then
     gosub poz
     char = 17
     call    PrintChar
    if mode = 2 then
     gosub poz
     char = 15
     call    PrintChar
     calibra = vt
    if mode = 3 then
     gosub poz
     char = 18
     call printchar
    if mode > 3 then
      mode = 0
     gosub poz
     char = 16
     call printchar
    check:
    SELECT CASE  MODE
    CASE 1
    PWM MOSFET, 255, 300
    CASE 2
        if w1 < (calibra-1) then
        pwm mosfet, 155, 200       'era 500
        low mosfet
    CASE 3
    LOW MOSFET
    END SELECT
    Poz:
                    LcdReg  =  %10000000 + 67        ' cursor  X
                    call    PrintCtrlLcd
                    call    PrintCtrlLcd
    End             'of program
    You can still shave some bytes...
    - you don't need 2 spi routines LCD_ByteOut & PrintDataLcd,
    - replace the For-To-Next loop with Repeat-Until ones,
    - if at all possible, try to skip the div32.
    - use internal timer for delays (not sure it will that much though
    - pwm with a high/low loop maybe?
    - select case for a couple a if-then
    couples of ideas like that. sounds like a nice challenge
