Soldering station
Results 1 to 38 of 38
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Soldering station
    I cannot run my simulation ( AMD Athlon64 X2 DualCore 4200+, 2 GB RAM ?!) ...
    It's this code OK ? Thanks !
    hyst            CON  2
    check:
    if mode >= 1 then
        if w1 < calibra-hyst     then pwm mosfet, 255, 300
        if w1 > calibra+hyst     then low mosfet
        if w1 = calibra+hyst-w1 then pwm mosfet,(w1*255)/(2*hyst), 300
    Bombay, India
    Looks good to me except I would make the first line this
    if w1 < calibra-hyst then high mosfet
    Dec 2008
    Ploiesti, ROMANIA
    Because of "structure" of my code (see memo subroutine) , this procedure don't work ... I don't have anymore acces to "memory"... I must try a different way, but I have such little space.
    Dec 2008
    Ploiesti, ROMANIA
    A new, working fine too, version...
    if buton = 0 then
    mode = mode + 1
    gosub memo
    gosub check
    Pause 100
    Goto Main
    and
    memo:
    if mode = 1 then
     gosub poz
     char = 17
     call    PrintChar
    if mode = 2 then
     gosub poz
     char = 15
     call    PrintChar
     calibra = vt
    if mode = 3 then
     gosub poz
     char = 18
     call printchar
    if mode > 3 then
      mode = 0
     gosub poz
     char = 16
     call printchar
    check:
    SELECT CASE  MODE
    CASE 1
    PWM MOSFET, 255, 300
    CASE 2
        if w1 < (calibra-1) then
              pwm mosfet, 155, 200
            low mosfet
    CASE 3
    LOW MOSFET
    END SELECT
    Still have BIG thermal inertia of iron soldering (about 7-8 degree)...
    Jan 2011
    Skopje,Macedonia
    where do you buy Nokia 3310 LCD displays?Can you put a link to the store?Thanks
    Do you use Solomon SL-10 soldering iron?
    Dec 2008
    Ploiesti, ROMANIA
    Yes, I use Pensol SL10. The display it's from " people sell everything don't need anymore " ... about 1 euro.
    FTR, Nokia 3310 or 5110 are basically the same. they use PCD8544 controller. Seems there's no longer a load of 1-2$ deal 'round here... probably because they are so popular
    Jan 2011
    Skopje,Macedonia
    Quote Originally Posted by fratello View Post
    Which program you use to make the "DIGITAL" text?Can you make a tutorial or something like that so I can learn something.
    I buy 3 Nokia 3310 mobile phones for 2euros.And now I have 8 of those in my lab
