Soldering station
Results 1 to 38 of 38
    Dec 2008
    Ploiesti, ROMANIA
    Default Soldering station
    Using Pensol SL10, one cheap 12F675 and N3310 display, I made for myself this soldering station. Works fine, the mos-fet remains cool, but... I wonder if my code it's the better way to drive the mos-fet and keep most accurate temperature of iron ("pwm mosfet, 255, 300").
    Any advice it's wellcome ! Thanks in advance !
    '*                   Statie digitala de lipit, cu display de NOKIA 3310        *
    '*                 Digital solering station with N3310 display            *
    '*                           by Dan Niculescu, june 2011                        *
    @ DEVICE PIC12F675, intrc_osc_noclkout, wdt_off, mclr_off
    DEFINE OSC  4
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    CMCON    = 7
    TRISIO   = %001001
    INTCON   = 0
    GPIO     = 0
    ANSEL    = %00010001
    ADCON0   = %10000001
    wpu      = %00000010
                D_C      var     GPIO.2
                SDIN     var     GPIO.4
                SCK      var     GPIO.5
                MOSFET   var     GPIO.1
              buton    var     GPIO.3
                LcdReg          var  byte
                x               var  byte
                y               var  byte
                z               var  byte
                a               var  byte
                PosX            var  byte
                PosY            var  byte
                Chr             var  byte
                LcdData         var  byte
                Offset          var  byte
                Char            var  byte
                adval           var  word
                w1              var  word
              vt              var  word
              cnt             var  byte
                grup            var  word
                mode               var  byte
              calibra         var  word
                i               var  byte
                DATA @0,$3E,$51,$49,$45,$3E,_       ' 0
                        $00,$42,$7F,$40,$00,_       ' 1
                        $42,$61,$51,$49,$46,_       ' 2
                        $21,$41,$45,$4B,$31,_       ' 3
                        $18,$14,$12,$7F,$10,_       ' 4
                        $27,$45,$45,$45,$39,_       ' 5
                        $3C,$4A,$49,$49,$30,_       ' 6
                        $01,$71,$09,$05,$03,_       ' 7
                        $36,$49,$49,$49,$36,_       ' 8
                        $06,$49,$49,$29,$1E,_       ' 9
                        $08,$08,$3E,$08,$08,_       ' +
                        $08,$08,$08,$08,$08,_       ' -
                        $00,$60,$60,$00,$00,_       ' .
                        $00,$02,$05,$02,$00,_       ' grad
                        $3E,$41,$41,$41,$22,_       ' C
                        $7F,$02,$0C,$02,$7F,_       ' M
                        $00,$00,$00,$00,$00,_       ' space
                     $08,$04,$7F,$04,$08,_       ' arrow up
                        $20,$40,$7F,$40,$20         ' arrow down
        Low D_C                                  'Command/Data
               LcdReg  =  %00100001         'LCD Extended Commands.
               call    PrintCtrlLcd
               LcdReg  =  $FF               'Set LCD Vop (Contrast).Initial $C5
               call    PrintCtrlLcd
               LcdReg  =  %00000110         'Set Temp coefficent.
               call    PrintCtrlLcd
               LcdReg  =  %00010011         'LCD bias mode 1:48.
               call    PrintCtrlLcd
               LcdReg  =  %00100000         'LCD Standard Commands
               call    PrintCtrlLcd
               LcdReg  =  $0C               'LCD in normal mode.  $0D inverse
               call    PrintCtrlLcd
    Pause 100
    Call CursorHome
    Pause 100
    Gosub LCD_Clear
    mode = 0
    Pause 500                ' time to give-up :)
    '===================== READING VOLTAGE ==============================
    low mosfet
    call Borderline
    pause 50
     vt=0
     grup=0
         for cnt = 1 to 20
     ADCON0.1 = 1
     WHILE ADCON0.1 = 1 : WEND
     Pause 10
     adval.HighByte = ADRESH
     adval.LowByte = ADRESL
     PAUSE 10
         vt=adval * 500
         vt=div32 1023
         grup=vt+grup
     PAUSE 10
         next cnt
     w1=grup / 20
    '===================== setting cursor for display the voltage
                    LcdReg  =  %10000000 + 25        ' cursor  X
                    call    PrintCtrlLcd
                    LcdReg  =  %01000011             ' cursor  Y
                    call    PrintCtrlLcd
    '===================== now display results
     if (w1 dig 2) <1 then
                    char = 16
                    call Printchar
                    Char = (w1 dig 2)
                    call    PrintChar
                    Char = (w1 dig 1)
                    call    PrintChar
     if (w1 dig 0) < 5 then
                    Char = 0
                    call    PrintChar
                    char = 5
                    call PrintChar
                    Char = 16
                    call    PrintChar
                    Char = 13
                    call  PrintChar
                    Char = 14
                    call  PrintChar
    if buton = 0 then
    mode = mode + 1
    gosub memo
    gosub check
    Pause 100
    Goto Main
    '================== L C D ===========================================
    CursorHome:     LcdReg  =  %10000000            ' cursor Home
                    call    PrintCtrlLcd
                    LcdReg  =  %01000000            ' cursor Home
                    call    PrintCtrlLcd
    PrintChar:      offset = Char * 5
                    for a = 1 to 5
                        read offset, LcdReg
                        call  PrintDataLcd
                        offset = offset + 1
                    next a
                    LcdReg = 0
                    call    PrintDataLcd
    PrintCtrlLcd:   D_C = 0
    PrintDataLcd:   for x = 1 to 8
                        SDIN = LcdReg.7
                        SCK = 1
                        LcdReg = LcdReg << 1
                        SCK = 0
                    next x
                    D_C = 1
    LCD_Clear:
                    PosX=0:PosY=0:Gosub LCD_GotoXY
                    D_C = 1
                    FOR Chr=1 TO 252
                        LcdData=0:Gosub LCD_ByteOut
                    next Chr
    LCD_GotoXY:
                    D_C = 0
                    LcdData=%01000000 | PosY :Gosub LCD_ByteOut
                    LcdData=%10000000 | PosX :Gosub LCD_ByteOut
    LCD_ByteOut:
                    SHIFTOUT SDIN,SCK,1,[LcdData]
    GotoXY:
    LcdReg = %01000000 | Posy : call    PrintCtrlLcd    'Y
    LcdReg = %10000000 | Posx : call    PrintCtrlLcd    'X
    memo:
    if mode = 1 then
     gosub poz
     char = 17
     call    PrintChar
     calibra = 4800
    if mode = 2 then
     gosub poz
     char = 15
     call    PrintChar
     calibra = vt
    if mode = 3 then
     gosub poz
     char = 18
     call printchar
     calibra = 10
    if mode > 3 then
      mode = 0
     gosub poz
     char = 16
     call printchar
    check:
    if mode >= 1 then
        if w1 < (calibra-2) then  pwm mosfet, 255, 300
        low mosfet
    Poz:
                    LcdReg  =  %10000000 + 67        ' cursor  X
                    call    PrintCtrlLcd
                    call    PrintCtrlLcd
    BorderLine:
    '=================================== RAW UP
          LcdReg  =  %10000000            ' cursor  X
          call    PrintCtrlLcd
          LcdReg  =  %01000000            ' cursor  Y
          call    PrintCtrlLcd
          for y = 0 to 83
          LOokup y, [$FF,$01,$01,$01,$01,_
                     $01,$01,$01,$01,$01,$01,$01,$01,$01,$FD,$FD,$FD,$85,$85,$FD,$FD,$79,_        'D
                     $01,$01,$FD,$FD,$FD,$01,$01,$79,$FD,$FD,$85,$A5,$ED,$ED,$69,$01,$01,_        'IG
                     $FD,$FD,$FD,$01,$05,$05,$05,$FD,$FD,$FD,$05,$05,$05,$01,_                    'IT
                     $F9,$FD,$FD,$25,$25,$FD,$FD,$F9,$01,$01,$FD,$FD,$FD,$81,$81,$81,$81,_        'AL
                     $01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$01,$FF] ,LcdReg
          call    PrintDataLcd
          next y
    '===================================  RAW 1 to 4
    for i= 1 to 4
    posx=0
    posy=i
    gosub GotoXY
                   lcdReg= $FF
                   call    PrintDataLcd
    next i
    for i = 1 to 4
    posx=83
    posy=i
    gosub GotoXY
                   lcdReg= $FF
                   call    PrintDataLcd
    next i
    '===================================  RAW DOWN
          LcdReg  =  %10000000
          call    PrintCtrlLcd
          LcdReg  =  %01000101
          call    PrintCtrlLcd
          for y = 0 to 83
          LOokup y, [$FF,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,_
                   $80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,$80,_
                   $80,$80,$80,$80,$80,$80,$80,$80,$FF] ,LcdReg
          call    PrintDataLcd
          next y
    End             'of program
    Default Re: Soldering station
    Hi Fratello,
    You REALLY like those Nokia graphic LCD . . .
    I think they're pretty cool too, Now as for USEFUL comments . . . According to the engineer from France who writes the Dark Side column in Circuit Cellar, . . Robert La Coste ? his suggestion is to use a PID loop to give you some Hysteresis to your temperature to prevent overshoot and undershoot of tip temp. Search the forum there is a pretty good one or more in circulation.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for advice !
    I found this : incPID_mc.pbp Author : Henrik Olsson. GREAT WORK !
    Unfortunately the code don't fit in my small 12F675 ; it's a solution to upgrade to a bigger PIC (18F2550 ?) but... for my small device it's another way ?!
    ...and yes, I like this display : it's verry cheap (about 1 euro) and easy to use. One 2x16 LCD display it's 6 euro and don't look so nice .
    Bombay, India
    I can assume you're almost at the limits of the code space with your current code. The best option, I reckon, to get reasonably good control with your existing setup would be to try PI control. As it is, you are using the PWM function. Just compute the proportional output to get a smoother control.
    Modify your check routine so that the PWM function outputs 255 when far lower than the setpoint, 0 when at it. Now, to compensate the offset of the temperature, you add the integral correction over time. This can be achieved quite easily with integer math alone.
    A typical P controller pseudo code
    Band con 10 ' this decides the band around SetPoint in which you want proportional control
    if Temp < SetPoint-Band then
    PWMout = 255 ' full heat
    if Temp > Setpoint+Band then
    PWMout = 0 ' full off
    ' within band, do Proportional heating
    Error = SetPoint+Band-Temp ' you want to get the bigger numbers for temp < sv
    PWMout = (Error*255)/(2*Band) ' get an output from 255 to 0 over the band from SV-Band to SV+Band, 50% at SV
    Adding integral is relatively easy too. You just need a variable to adjust the error over time. Or use a button to snapshot the error and add it as an offset.
    IntErr var byte
    IntErr = IntErr+(Error/IntTime) ' integrate the error over time
    PWMout = PWMout + IntErr
    if PWMout > 255 then PWMout = 255 ' limit to usable PWM range
    PWM Mosfet, PWMout, 300 ' transfer to the mosfet
    Just some ideas.
    Dec 2008
    Ploiesti, ROMANIA
    Thank You so much ! I try and I post the results.
    Dec 2008
    Ploiesti, ROMANIA
    I cannot run my simulation ( AMD Athlon64 X2 DualCore 4200+, 2 GB RAM ?!) ...
    It's this code OK ? Thanks !
    hyst            CON  2
    check:
    if mode >= 1 then
        if w1 < calibra-hyst     then pwm mosfet, 255, 300
        if w1 > calibra+hyst     then low mosfet
        if w1 = calibra+hyst-w1 then pwm mosfet,(w1*255)/(2*hyst), 300
    Bombay, India
    Looks good to me except I would make the first line this
    if w1 < calibra-hyst then high mosfet
    Dec 2008
    Ploiesti, ROMANIA
    Because of "structure" of my code (see memo subroutine) , this procedure don't work ... I don't have anymore acces to "memory"... I must try a different way, but I have such little space.
    Dec 2008
    Ploiesti, ROMANIA
    A new, working fine too, version...
    if buton = 0 then
    mode = mode + 1
    gosub memo
    gosub check
    Pause 100
    Goto Main
    and
    memo:
    if mode = 1 then
     gosub poz
     char = 17
     call    PrintChar
    if mode = 2 then
     gosub poz
     char = 15
     call    PrintChar
     calibra = vt
    if mode = 3 then
     gosub poz
     char = 18
     call printchar
    if mode > 3 then
      mode = 0
     gosub poz
     char = 16
     call printchar
    check:
    SELECT CASE  MODE
    CASE 1
    PWM MOSFET, 255, 300
    CASE 2
        if w1 < (calibra-1) then
              pwm mosfet, 155, 200
            low mosfet
    CASE 3
    LOW MOSFET
    END SELECT
    Still have BIG thermal inertia of iron soldering (about 7-8 degree)...
    Jan 2011
    Skopje,Macedonia
    where do you buy Nokia 3310 LCD displays?Can you put a link to the store?Thanks
    Do you use Solomon SL-10 soldering iron?
    Dec 2008
    Ploiesti, ROMANIA
    Yes, I use Pensol SL10. The display it's from " people sell everything don't need anymore " ... about 1 euro.
    FTR, Nokia 3310 or 5110 are basically the same. they use PCD8544 controller. Seems there's no longer a load of 1-2$ deal 'round here... probably because they are so popular
    Jan 2011
    Skopje,Macedonia
    Quote Originally Posted by fratello View Post
    Which program you use to make the "DIGITAL" text?Can you make a tutorial or something like that so I can learn something.
    I buy 3 Nokia 3310 mobile phones for 2euros.And now I have 8 of those in my lab
    A fullblown PID is probably overkill but, for the record, incPID_mc is the multichannel version of the PID-filter. It works fine with a single channel but it takes a lot more codespace than the original incPID routine.
    You can find v1.5 of the single channel version in this post. And with THAT said it still won't fit the 12F675 due to the limited amount of RAM available in that device.
    What I'd do is probably something in the line of what Jerson showed but I'd also add a bias or feedforward based on the setpoint (not the error). If you know that in order to maintain a temperature of say 250°C you need a dutycycle of 40% then, once you're within the window of the regulator you enable the P(I) regulator and add the bias/feedforward to the output.
    You'll need to work out a suitable bias/feedforward "gain" since it's not going to be perfectly linear. Since the system (probably) heats up faster than it cools down and you can't have "negative drive" you should err on the low side for the bias/feedforward so that IT alone can never drive the temp OVER the setpoint. If it does the regulator can't bring it down since it can never go "below" 0% PWM.
    EDIT: The original version of incPID, which can be found i post 1 in the thread above, compiles to 314 words on the 12F675 and uses 29 bytes of RAM. Depending on how many bytes of RAM your application uses it MIGHT fit but again, it's probably not worth it.
    probably http://en.radzio.dxp.pl/bitmap_converter/
    You draw you screen at the right size (84x48 pixels) in Photoshop, MsPaint (whatever floats your boat), save it as monochrome BMP, then import it in the software, generate the table, then import it in your code.
    EDIT: also check this out
    http://www.picbasic.co.uk/forum/cont...Nokia-3310-LCD
    Hello Henrik,
    Probably not in Sweden or the USA, but in Romania, it might be very well worth it. Import tax is high there, wages not so much . . . Thanks for helping him.
    JS
    Dec 2008
    Ploiesti, ROMANIA
    Thanks to all for support !!! Glad to see people helping others...
    I will take attention to inc_PID, but ... now my code is 1002 words . The best (so far) solution it's to "upgrade" the PIC (maybe 18F...) but, for moment, I will try to keep this "low-cost variant".
    Try to compact your code. Maybe repeated code can be a subroutine etc.
    Also if you use flags, then declare them as BIT and not as BYTE or even worse as WORD.
    If you need a BYTE variable, do not declare as WORD.
    Dec 2008
    Ploiesti, ROMANIA
    Whitout "graphics elements" the code it's 659 words. Maybe it's a good start for use PID ?! (+314 words)
    ' version 2
    DEFINE OSC  4
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    CMCON    = 7
    TRISIO   = %001001
    INTCON   = 0
    GPIO     = 0
    ANSEL    = %00010001
    ADCON0   = %10000001
    wpu      = %00000010
                D_C      var     GPIO.2
                SDIN     var     GPIO.4
                SCK      var     GPIO.5
                MOSFET   var     GPIO.1
              buton    var     GPIO.3
                LcdReg          var  byte
                x               var  byte
                y               var  byte
                z               var  byte
                a               var  byte
                PosX            var  byte
                PosY            var  byte
                Chr             var  byte
                LcdData         var  byte
                Offset          var  byte
                Char            var  byte
                adval           var  word
                w1              var  word
              vt              var  word
              cnt             var  byte
                grup            var  word
                mode               var  byte
              calibra         var  word
                DATA @0,$3E,$51,$49,$45,$3E,_       ';// 0
                        $00,$42,$7F,$40,$00,_       ';// 1
                        $42,$61,$51,$49,$46,_       ';// 2
                        $21,$41,$45,$4B,$31,_       ';// 3
                        $18,$14,$12,$7F,$10,_       ';// 4
                        $27,$45,$45,$45,$39,_       ';// 5
                        $3C,$4A,$49,$49,$30,_       ';// 6
                        $01,$71,$09,$05,$03,_       ';// 7
                        $36,$49,$49,$49,$36,_       ';// 8
                        $06,$49,$49,$29,$1E,_       ';// 9
                        $08,$08,$3E,$08,$08,_       ';// +
                        $08,$08,$08,$08,$08,_       ';// -
                        $00,$60,$60,$00,$00,_       ';// .
               call    PrintCtrlLcd
               LcdReg  =  $E6               'Set LCD Vop (Contrast).Initial $C5
               call    PrintCtrlLcd
               call    PrintCtrlLcd
               call    PrintCtrlLcd
               call    PrintCtrlLcd
               call    PrintCtrlLcd
    Pause 100
    Call CursorHome
    Pause 100
    Gosub LCD_Clear
    mode = 0
    low mosfet
     vt=0
     grup=0
         for cnt = 1 to 20
     ADCON0.1 = 1
     Pause 10
     PAUSE 10
         vt=adval * 500
         vt=div32 1023
         grup=vt+grup
     PAUSE 10
         next cnt
     w1=grup / 20
    '~~~~~~~~~~~~~~~~~ setting cursor for display the voltage
                    call    PrintCtrlLcd
                    call    PrintCtrlLcd
    '~~~~~~~~~~~~~~~~~ now display results
                    char = 16
                    call Printchar
                    Char = (w1 dig 2)
                    call    PrintChar
                    Char = (w1 dig 1)
                    call    PrintChar
                    Char = 0
                    call    PrintChar
                    char = 5
                    call PrintChar
                    Char = 16
                    call    PrintChar
                    Char = 13
                    call  PrintChar
                    Char = 14
                    call  PrintChar
    if buton = 0 then
    mode = mode + 1
    gosub memo
    gosub check
    Pause 100
    Goto Main
                    call    PrintCtrlLcd
                    call    PrintCtrlLcd
                    for a = 1 to 5
                        read offset, LcdReg
                        call  PrintDataLcd
                        offset = offset + 1
                    next a
                    LcdReg = 0
                    call    PrintDataLcd
                        SDIN = LcdReg.7
                        SCK = 1
                        SCK = 0
                    next x
                    D_C = 1
    LCD_Clear:
                    D_C = 1
                    FOR Chr=1 TO 252
                    next Chr
    LCD_GotoXY:
                    D_C = 0
    LCD_ByteOut:
    memo:
    if mode = 1 then
     gosub poz
     char = 17
     call    PrintChar
    if mode = 2 then
     gosub poz
     char = 15
     call    PrintChar
     calibra = vt
    if mode = 3 then
     gosub poz
     char = 18
     call printchar
    if mode > 3 then
      mode = 0
     gosub poz
     char = 16
     call printchar
    check:
    SELECT CASE  MODE
    CASE 1
    CASE 2
        pwm mosfet, 155, 200       'era 500
        low mosfet
    CASE 3
    LOW MOSFET
    END SELECT
    Poz:
                    call    PrintCtrlLcd
                    call    PrintCtrlLcd
    End             'of program
    You can still shave some bytes...
    - you don't need 2 spi routines LCD_ByteOut & PrintDataLcd,
    - replace the For-To-Next loop with Repeat-Until ones,
    - if at all possible, try to skip the div32.
    - use internal timer for delays (not sure it will that much though
    - pwm with a high/low loop maybe?
    - select case for a couple a if-then
    couples of ideas like that. sounds like a nice challenge
    Another thing about the graphic part, I've messed with it a lot recently and I saved a load of code space by skipping the whole SELCT-CASE + Lookup thing by using something like
    SearchChar:
            read (index), char
            if char == TheCharYoureLookingFor then
                Gosub PrintIt
                index=endtable
            index=index+6
            if (index)<endtable then SearchChar
    But you need to modify a little bit the way your DATA lines are done.
                DATA @0,"0",$3E,$51,$49,$45,$3E,_       ';// 0
                        "1",$00,$42,$7F,$40,$00,_       ';// 1
                        "2",$42,$61,$51,$49,$46,_       ';// 2
                        "3",$21,$41,$45,$4B,$31,_       ';// 3
                        "4",$18,$14,$12,$7F,$10,_       ';// 4
                        "5",$27,$45,$45,$45,$39,_       ';// 5
                        "6",$3C,$4A,$49,$49,$30,_       ';// 6
                        "7",$01,$71,$09,$05,$03,_       ';// 7
                        "8",$36,$49,$49,$49,$36,_       ';// 8
                        "9",$06,$49,$49,$29,$1E,_       ';// 9
                        "+",$08,$08,$3E,$08,$08,_       ';// +
                        "-",$08,$08,$08,$08,$08,_       ';// -
                        ".",$00,$60,$60,$00,$00,_       ';// .
                        "G",$00,$02,$05,$02,$00,_       ' grad
                        "C",$3E,$41,$41,$41,$22,_       ' C
                        "M",$7F,$02,$0C,$02,$7F,_       ' M
                        " ",$00,$00,$00,$00,$00,_       ' space
                        "^",$08,$04,$7F,$04,$08,_       ' arrow up
                        "_",$20,$40,$7F,$40,$20         ' arrow down
    so when you want to display your grad character, just need to send G to that routine above. Simple... if it fits the EEPROM ...
    314 words is the size when compiled by itself. Depending on what functions your code uses it might already have one or more of the PBP library routines included meaning the total size will be less than whatever + 314 words.
    But like I said, the problem in this case is likely the amount of available RAM. If my count is correct your code uses 23 bytes and the original incPID uses 29 bytes, then, if I'm not mistaken, PBP adds ~24 bytes for its internal use (might change depending on what library routines are used, I don't know for sure). All in all this adds up to more than the 64 bytes of RAM available on the 12F675.
    What I meant with not being worth it wasn't that you should throw a "bigger" PIC at the issue. I meant that I don't think the effort of implementing incPID is worth it considering the performance gain you might get compared to the aproaches already discussed. Sure, it it fits it's wort a try, if it doesn't fit I'd try to make do with what's available.
    Finally incPID was written in order to be versatile and easy to use. It's probably possible to reduce the size and amount of RAM needed further if adapting it to a specific application - but that's up to anyone using it to do.
    Aug 2010
    Maryland, USA
    I'm sure there is something I am missing here but,
    Do you think you can do better then this? Or need to? Now if its an excersize in learning and just the fun of doing it, well thats a great reason. But I would think the tip temp will cool that much if you just blow on the tip. but to raise it will take full power for a few seconds to get it back, then it will overshoot. Just my HO.
    -Bert
    Do you think you can do better then this? Or need to? Now if its an exercise in learning and just the fun of doing it, well that's a great reason. But I would think the tip temp will cool that much if you just blow on the tip. but to raise it will take full power for a few seconds to get it back, then it will overshoot. Just my HO.
    Just so we are all playing on the same field . . . are we talking degrees C or degrees F ? I am guessing Centigrade so that's more like 13 or 14 Fahrenheit.
    Check out Robert's article:
    http://itech.fgcu.edu/faculty/zalews...PIDcontrol.pdf
    Sure enough, it's not Kelvin... just sayin
    Hey! He (Kelvin) used to work for me . . .
    Bombay, India
    I can hazard a guess that changing this section of code
         vt=adval * 500
                vt=div32 1023
                grup=vt+grup
                PAUSE 10
    to this
    vt=adval >> 1
    grup=vt+grup
    PAUSE 10
    might save you a bit of code & ram space. But, I've not checked this, so, you'll beware. Again, if you notice,
    I've used an approximation of divide by 2(500/1000) for 500/1023 instead of 1/2.046 I do not think it will matter much if you calibrate
    the readings.
    Dec 2008
    Ploiesti, ROMANIA
    Wow ! Great support here ! Thanks to all !!!
    In first post You can see : the temperature it's in Celsius degrees. The PID control it's a verry good ideea; sure I will use in future projects !
    But...I try to do like Mr. Ioannis :
    if w1 < (calibra - 5) then pwm mosfet 255, 300
    if w1 < (calibra - 3) then pwm mosfet 155, 250
    if w1 < (calibra - 1) then pwm mosfet 100, 200
    I think to reduce the "power" of heating by adjusting the pwm factors... It's OK ?!
    1. On the above code you do not need the 3 endif.
    2. The credit is not for me. Maybe Jerson's?
    Dec 2008
    Ploiesti, ROMANIA
    Oh, I see. OK, but take into account what I noted on the post.
    It is slow and may oscillate. I am sure it will. Also depending on the resolution, the dead band may be large. Of course the larger it is the less it will oscillate.
    Dec 2008
    Ploiesti, ROMANIA
    I wrote this :
    but the heating start ONLY when w1 < (calibra - 3) !
    Why don't start when w1 < (calibra - 1) ?!?
    And what is the value of w1 then?
    Dec 2008
    Ploiesti, ROMANIA
    Example : if calibra (value for memory, set by user) is 140, the heating start at 137.
    I wrote the routine for display those two values : w1 (current temperature) and calibra. The led blink ( PWM out) only when w1 < ( (calibra-3) !
    if mode = 2 then
     call poz
     char = 16
     call    PrintChar
     calibra = vt
                    call    PrintCtrlLcd
                    LcdReg  =  %01000011 + 1         ' cursor  Y
                    call    PrintCtrlLcd
     if (vt dig 2) <1 then
                    char = 16
                    call Printchar
                    Char = (vt dig 2)
                    call    PrintChar
                    Char = (vt dig 1)
                    call    PrintChar
                    Char = (vt dig 0)
                    call    PrintChar
                    Char = 16
                    call    PrintChar
                    Char = 13
                    call  PrintChar
                    Char = 14
                    call  PrintChar
                    Char = 16
                    call    PrintChar
                    Char = 15
                    call    PrintChar
    Jan 2011
    Skopje,Macedonia
    Fratello,can you make a code with MAX6675 thermocouple cold junction sensor?I have one,so I want to use it.
    Dec 2008
    Ploiesti, ROMANIA
    Hi! Why don't You write your own code ?!
    California, USA
    Post Re: Soldering station
    Quote Originally Posted by SKOLS1 View Post
    Here, I'm familiar with the MAX6675 so I'll give you a start...
    This should read the MAX6675 and display degrees C & degrees F on a LCD display.
    (Pin aliases for LCD not shown, only for the MAX6675)
    'Alias pins - MAX6675 temp sensor
    MXSCLK      var     PORTD.0   'MAX6675 Clock
    MXCS        var     PORTD.2   'MAX6675 Chip Select
    MXSO        Var     PORTD.3   'MAX6675 Serial Data
    '--Variables-----------------------
    kTemp       var     word    'raw data from MAX6675
    tempC       var     word    'temperature in degrees C
    tempF       var     word    'temp C converted to degrees F
    '-----------Read and display temperature from MAX6675-----------
        LOW MXCS                            'chip select low
        shiftin MXSO, MXSCLK, 0, [kTemp\16] 'shift in the data
        HIGH MXCS                           'chip select high
        tempC = kTemp >> 5                  'side shift to ditch the stuff to the right of the decimal point and just show whole degrees)
        tempF = ((tempC * 18)/10) + 32      'convert C to F
       lcdout $fe,1,dec tempC," degrees C  ",$fe,$c0,dec tempF," degrees F  "   'display the data on LCD
    Dec 2008
    Ploiesti, ROMANIA
    So it's possible to write code for 16F628A (16F648A), for example...since 12F675 don't have enough ports. And working with large fonts (if using Nokia LCD disply) , memory, pre-setting, etc...
