Array copy
Results 1 to 4 of 4
Thread: Array copy
    Sep 2005
    Campbell, CA
    Default Array copy
    I know I can fill an array using the ArrayRead command,
    ArrayRead,TestArray,["0","1","2","3","4"]
    But is there a way I can copy part of an array into another using this command?
    If I wanted to copy SourceArray elements 4-13 into DestinationArray the following
    construct would be nice.
    ArrayRead DestinationArray,[Skip4 SourceArray \10]
    But this doesn't work. Is there some way other than a FOR - NEXT loop to
    perform this operation quickly?
    Charles Linquist
    Sep 2005
    Campbell, CA
    Default Re: Array copy
    I figured it out.
    ArrayRead DestinationArray[2],[STR SourceArray [4] \10]
    Starts with the 4th element of SourceArray and loads 10 elements into the DestinationArray starting at element 2
    Charles Linquist
    Sep 2005
    Campbell, CA
    I figured it out.
    BUT - I find that the array element designators (2 & 4 in this case) must be constants
    Charles Linquist
    Are you sure that it need to be constants?
    If yes, all the joy is lost now...
