Hello Steve,
For a good example that I ran into about 1 week ago....
I was using a 675 and a 648A with serial communication between them. The 648A is attached to a LCD for a homemade "Backpack".
I was using 675 for Pulsin, and decided to increase my frequency using another 648A pin and making a Psuedo PWM signal The Pulse was a instant on, Instant off, so the timing was very short. On my Old scope I was showing nothing. I had to go to my FLUKE, and my FLUKE showed a "Spike". Though that spike was just a thin line, I *knew* something was there. I took my old scope, and set it to the EXACT settings of my fluke. I still could not see the "Blurp". I adjusted the light density (which was EXTREMELY bright) and STILL could not see the Blip. After playing a little bit, I was barely able to see the blip on the scope. And I had to slow down the scope to see them... This has been the first and only time I have run into this problem. I switched to a 60 mhz scope, and had the same exact problem seeing this Blip. If it wasn't for my fluke, I am quiet sure, I would have missed it all together.
Though I really like the FLUKE VOM's too, I actually prefer the old meter VOM over the LCD's for many things. The meter tells me a lot by its movement...I can't tell if the LCD kind is switching modes because of bad contacts, or varying voltage <g>. But either way...If I were to buy, It definitely would be a Fluke... They are shock Proof, water proof, and Definitely worth the extra money. Yeah.. they are small, but they sure are wonderful to use. I think they run 600 dollars (for the 123) on Ebay. But they are workhorses. The only thing I do not like about the 123, is that the battery pack doesn't last a long time. Maybe 30 min to 45 min or so. The 123 does have a automatic battery cycler, but anyone who REALLY nows about Nicads, KNOWS you never discharge NICAD batteries to zelch. Big mistake, yet Most folks are clueless on this.
Dwayne
Ability to Fly:
Pilots that are Flying:
