High Voltage analog multiplexers
Results 1 to 3 of 3
    brighton
    Exclamation High Voltage analog multiplexers
    Hello All
    I am just looking for advice from anyone with regards to a project which i need to carry out at work.
    i have a common supply of 110v dc which i need to apply to 16 different channels
    so that instead of using 16 different relays i can just use an analog multiplexer so the output can be selectable dependant on the digital input such as the DG406
    http://www.maxim-ic.com/datasheet/index.mvp/id/1002
    Not sure if there is such an IC that can be use at high voltage
    Isaac
    Default Re: High Voltage analog multiplexers
    The DG406 has a max input of 30V so it would not work in this application. Other than relays, you could use high voltage transistors or FETs but you would have to manage the on/off timing yourself based on the response time of the parts used.
    Tim Barr
    brighton
    Thanks falingtrea
    Thats what i thought as i knew the DG406 was not capable of supplying 100v
    i just thought that there might had been a High Voltage version or similar
    Isaac
