Input question from a newbe
Results 1 to 40 of 40
    Default Re: Input question from a newbe
    ADC, comparator?!? Arwe you sure it's just not a sort of open collector output you have on hand? What if you attach a pull up resistor to it.
    In meantime i'll count my millions
    brighton
    Not sure what you are trying to do but 0.7v is quite low
    but if that's what you are measuring and assuming its the correct voltage why not fed it via an op amp then adc
    the adc is capable to do the job without the opamp in this specific case though.
    (0.7/5)*1023=143
    (0.7/5)*255=36
