Input question from a newbe
Results 1 to 40 of 40
    Jul 2011
    Default Re: Input question from a newbe
    I would suggest trying a lower value resistor but it seems you've already done that.
    I think I found the problem, although not entirely sure why it did what it did. The initial LED circuit had one LED and when I added the second (in haste) I shared the same dropping resistor (based on the fact that that both LEDs would never be on at the same time). Giving each LED its own resistor appears to have solved the problem.
    What is the voltage at the pin (on the PIC) when the LED is on and off? Are you running the PIC on 5V?
    The voltage at the pin is 5.6V Off and 0V (0.5mv on my meter) On
    The PIC is running on 5V (via 7805) but both circuits are fed from the same 12V supply, that is how it will be with the final circuit.
    thanks again.
    Jul 2011
    Update and further question:
    I'm sensing the state of 6 LED's using the resistor approach which a great with 5 out of the 6 LEDs. I'm using a resistor of great enough value not to light the LED.
    The problem with one of the LED is that the sensing is unreliable (sometimes it would read the LED coming on and sometimes it wouldn't). Using a meter I found that when the problem LED was on the voltage was ~1.2V at point 2 of the original diagram where the other 5 were at close to zero. It is strange because all 6 LEDs are in the same circuit. The issue appears to be that the PIC sees the ~1V as high which makes sense.
    I did tried the lm78L05 to92 approach but couldn't stop it causing the LED to be illuminated when the LED was off.
    Any ideas?
    Jul 2011
    This forum is magic, I ask a question after spending hours trying to fix something and then within an hour I come up with an answer. The answer appears to be use a 5v zener diode is series with the resistor.
    So my next question is what is next weeks lottery numbers?
    The one I have
    Jul 2011
    Not expecting an answer from Steve because he should have collected his winnings by now
    For everyone else; I want to track when a switch (which is in an existing circuit) is pressed and was hoping to use the same approach. The problem is the voltage is 0.7V when push to make switch is open and 0V when closed and that doesn't appear to be enough of a range.
    ADC, comparator?!? Arwe you sure it's just not a sort of open collector output you have on hand? What if you attach a pull up resistor to it.
    In meantime i'll count my millions
    brighton
    Not sure what you are trying to do but 0.7v is quite low
    but if that's what you are measuring and assuming its the correct voltage why not fed it via an op amp then adc
    Mar 2009
    Quote Originally Posted by Bdlhome View Post
    Probably better for you to define track for your "0.7V" being presented to the PIC....
    1. Immediately being notified when the switch is pressed? - use a comparator with PIC's comparator interrupt.
    2. hopefully catching someone pressing a switch while polling the ADC Result very frequently? - use ADC and a tight main loop.
    Jul 2011
    Quote Originally Posted by HankMcSpank View Post
    Both would probably work, although #1 is probably better for my project. Having said that, I'm using this project as a learning experience, so I will try both.
    Thanks everyone
    Jul 2011
    I have been using the resistor approach and sensing the voltage when the LED is off and then that drops close to zero when the LED is illuminated.
    There are 6 LEDs in play and 5 out of the 6 work flawlessly but I'm having problems with one and it is driving me crazy.
    Intermittently the PIC reads the input as positive even when the LED is illuminated just on that one LED. Further information to set the scene:
    This circuit is in a car
    When the engine isn't running it appears much more reliable (suggesting perhaps noise or voltage related)
    With the engine running, turning on the courtesy light will sometimes correct the reading (falsely reading until the courtesy light is turned on and then it reads correctly). This again suggested voltage but turning on something else like the headlights does not have the same effect.
    I've tried varying the resistor value and putting in capacitors but has no effect.
    Anybody have any ideas? I'm pulling my hair out here.
    Jul 2011
    To make matters worse (or maybe help diagnose) I went back to one of my earlier boards and it works perfectly..
    On the newer boards (I have 3 that are all doing the same) that are having the problem, touching the resistor on the side before it enters the PIC makes it work. Is it the capacitance in my finger that is causing it to work?
    The layout of the boards (old to new) is virtually identical, I moved a couple of components a little to make the board a little smaller (we are only talking 1/8-1/4 of an inch). The components are all the same values but some are different manufactures, but really clutching at straws at that point. I don't have a scope handy (although I will have access to one on Wednesday) so cant really see what is going on.
    Apr 2007
    Pennsylvania, USA
    What PIC are you using? Also what specific pin are you using?
    Shawn
    Jul 2011
    Quote Originally Posted by spcw1234 View Post
    16F877a and RB4
    Apr 2007
    Pennsylvania, USA
    Nothing specific to that pin that should cause an issue. Have you measured voltage at that pin? It sounds like it is floating, possibly due to a broken trace or a bad connection.
    Shawn
    Jul 2011
    When measuring the voltage at the pin with the LED illuminated the presence of the meter causes the input to behave as expected and the voltage is around 300-400mv. With the LED off the voltage is ~5.4V. I have three boards that are all exhibiting the same problem so don't think it is broken trace or bad connection.
