pin voltage while programming
Results 1 to 5 of 5
    Default Re: pin voltage while programming
    Depends how you design your thing. On most sensitive programmer, you can set the target Vdd voltage, that solve the problem, if any. An home made LDO for Vdd and resistor divider for PGC/PGD? could be this too. Never tried it though.
    You can Isolate your PIC from the "external world" with jumpers and diode, that's for sure, but first, check what happen on I/O while programming. I doubt you'll see 5 Volts peaks, more likely some spurious volts.
    Another thing... does this board will require some firmware update? Case not, you could just solder the pic on, program it, then populate the other components.
    I isolate VPP and VDD, never worried about PGD and PGC. But I never thought about it either...
    Hi guys,
    Thank you for your thoughts,
    Actually i can isolate both VDD, PGD, PGC and VPP either using jumpers or using these pins only for ICSP.
    The problem are the other pins. I'm not being able to accurately measure the voltage peeks but there's definitely voltage in those pins ( not all of them though ).
    If one of them peeks more than 3V i may damage the component.
    Rui
    Isolate Vdd and Vss then.... or, like I said, use a programmer allowing to modify it's Vdd... OR modify it yourself, not that hard.
