PWM fan speed control with a 12F683
Results 1 to 18 of 18
Threaded View
    Sep 2010
    Las Vegas, NV
    Default PWM fan speed control with a 12F683
    Ladies and Gents,
    I'm trying to use a 12F683 to control a fan motor. I want to be able to push a button and have the fan cycle through speeds from off to high in 3 steps.
    The problem is I can't figure out how to use PWM indefinitely.
    This is my program. I've got the push button on GPIO.3 and the fan currently on GPIO.5. It works kinda but the selected speed only lasts for the length of time PWM is set. During that time you can't select another speed.
    Your thoughts would be appreciated.
    clear
    define osc 4
    @ device mclr_off 'the input will be through GPIO.3
    ansel = 0 'all ports digital
    cmcon0 = 7 'turn off comparators
    adcon0 = 0
    touchnumber var byte 'count the number of touches
    outTOfan var gpio.5 'LED symbolizing fan speed
    trisio = %001111
    touchnumber = 0
    starthere:
    outtofan = 0
    If gpio.3 = 1 then goto main
    goto starthere
    touchnumber = touchnumber + 1
    if touchnumber =4 then touchnumber = 0
    select case touchnumber
    case 0
    gpio.5 = 0
    case 1
    pwm gpio.5, 60,1000
    case 2
    pwm gpio.5,150, 1000
    case 3
    pwm gpio.5, 255, 1000
    end select
    goto starthere
