I/O - From Define to code ... must be easy
Results 1 to 10 of 10
    Default Re: I/O - From Define to code ... must be easy
    I think of some other ways, but it's damn too much coding for a so simple thing The asm side's still good enough though. It would have been soo easy if we could do
    DEFINE LCD_EN_LINE PORTC,1
    and then
    LCD_EN_LINE VAR BIT EXT... BUT NOPE
    OR
    even easier.. have them ready to use, nothing to hack...
    Why I do prefer the DEFINE way... hahaha, I have no idea Probably to fit with PBP LCDOUT, HSEROUT, DEBUG etc etc etc
    This will blink an LED on any pin, as specified in the BLINK_TEST define.
    If the define is commented out, it will bypass the blinky and start at the main program.
    DEFINE BLINK_TEST PORTB,0
    ' Variables, Constants etc.
    ;----[Blinky test]------USE( DEFINE BLINK_TEST PORTB,0 )-----------------
    BLINK_LED VAR BIT EXT
    @ #undefine BLINK_LED
    @ #define BLINK_LED BLINK_TEST
    @ ifdef BLINK_TEST
        INCLUDE "AllDigital.pbp"
        Blink:
            TOGGLE BLINK_LED
            PAUSE 500
        GOTO Blink
    @ endif
    hhhhhhhhhhhhhhhhhhhhhaaaaaa! I knew it was something "easy", just never though of the #undefine twist...mmm... something else to chew on
    Thanks Mr Tech Support
    So, are you saying that this is almost like conditional compilation? By almost I mean that as far as I understand it, it will alwyas compile the code but depending on if the DEFINE exists or not the compiled ASM code will or will not be assembled?
    Is that correct? If not, could Steve or Darrel elaborate a bit as I'm curious?
    Thanks!
    Yup, some black magic in conditional compilation, IFDEF, IFNDEF, #DEFINE, #UNDEFINE, to name only but those. Pretty slick and so usefull once you get the concept and play with.
    Lots of great feature in asm and MPASM. If you' wanted, you may have one code template and it will fit every hardware depending how you deal with the conditional compilation. Good example, Microchip Framework. One code fits all(most) of their development boards.
    On the top of your code, you provide some USER configurable setting, says regular LCD or GLCD, USB to RS232, PIC model and so forth... endless possibilities.
    Pretty addictive.
    I smell that you are cooking something here Steve, but cannot follow you.
    I'll wait to see the smartie that you will show us... anxiously
    Always looking for convenience, but don't always use it
    "What you smell is a fart, not much " <-- highlight with your mouse...
